Go Back   HeliFreak > Blogs > Silverexpress01
Trex 250 SE Flybarless: Updated 10/5/10
Posted 08-22-2010 at 09:26 AM by Silverexpress01
Updated 03-05-2013 at 03:15 PM by Silverexpress01
Follow down for updates:
Weight RTF:
Most current state is about 250-260 grams.
Mechanics
- Trex 250 SE Kit (No Electronics - Ebay $139.99 USD)
- KDE CNC Bottom Plate
- Boca Bearings for mainshaft
- Align 205mm carbon blades
- DIY carbon tail rotor push rod
- 15T pinion
- 120T main gear
- Microheli CNC side braces (from MH FBL head kit)
-37mm tail blades on very windy days
-40mm tail blades on not so windy days
-Removed tail boom braces
Electronics
- Skookum SK-720 Flybarless Controller w/Spektrum Satellite
- Castle Creations 10 amp BEC
- Castle Creations 25 amp ESC
- Scorpion HK2206-3900kv BL motor
- Hitec 5065mg's for the cyclic @ 6v and with Karbonite gears
- Hyperion DS11 GCB @ 6v for Tail
Flybarless Head
Align DFC
Update: 10/5/10
Redid the wiring, and purchased a new canopy in blue.
Update: 2/17/13 See this link for my RF6.5 simulation of the Trex 250.
http://www.rcgroups.com/forums/showthread.php?t=1400912
Update 3/2/13: Latest re-incarnation!
I've been flying this little bad boy since Dec 2009. It started out as plain flybarred 250, and the attached pics with the green canopy and fin is the latest setup. My goal was to lighten it up and simplify it as much as I could.
Click image for larger version
Name:	Fig 1_Stuff Needed 2010jun12.jpg
ID:	463   Click image for larger version
Name:	Fig 2_3M Mounting Tape 2010jun12.jpg
ID:	464   Click image for larger version
Name:	Fig 3_SK-720 Mounting 2010jun12.jpg
ID:	465   Click image for larger version
Name:	Fig 4_Mounting of CC ESC.jpg
ID:	466   Click image for larger version
Name:	Fig 5_cc_bec_wiring_diagram.jpg
Name:	Pic 6 ESC JST connectors.jpg
ID:	468   Click image for larger version
Name:	Pic_7 Finished wiring of JSTs for ESC 2010jun13.jpg
ID:	469   Click image for larger version
Name:	Pic_8 Test programming connection 2010jun14.jpg
ID:	470   Click image for larger version
Name:	Trex 250SE SK-720 Wiring 2010jun05.jpg
ID:	471   Click image for larger version
Name:	Eagletree rpm sensor.jpg
Name:	Trex 250SE FBL_1 2010oct3.jpeg
ID:	547   Click image for larger version
Name:	Trex 250SE FBL_2 2010oct3.jpeg
ID:	548   Click image for larger version
Name:	Trex 250SE FBL_3 2010oct3.jpeg
ID:	549   Click image for larger version
Name:	Trex 250SE FBL_4 2010oct3.jpeg
ID:	550   Click image for larger version
ID:	1009   Click image for larger version
Total Comments 4
  1. Old Comment
    how much do u want for all of it?
    Posted 08-22-2010 at 10:41 AM by apetersen apetersen is offline
    Updated 09-05-2010 at 12:46 PM by Silverexpress01
  2. Old Comment
    Silverexpress01's Avatar
    Quote:
    Thanks for the offer, but it is not for sale. Took me awhile to build it up, and at this moment, I don't have the time to build up another one.
    Posted 09-05-2010 at 12:46 PM by Silverexpress01 Silverexpress01 is offline
  3. Old Comment
    very nice setup,
    i am curious as to the side braces? cant seem to find them, you list Microheli CNC side braces (from MH FBL head kit) link? is this what was used to support the back side frame so the SK720 can fit in?
    thanks
    Posted 10-10-2010 at 02:27 AM by josefk josefk is offline
  4. Old Comment
    Quote:
    Originally Posted by josefk View Comment
    very nice setup,
    thanks
    Yes. The side braces are not sold seperately, and thus are only available with the flybarless head assembly....$35.95 USD
    http://www.experiencerc.com/store/mh...ex-p-2929.html
    Posted 10-13-2010 at 08:22 AM by Silverexpress01 Silverexpress01 is offline
