HeliFreak
HeliFreak (http://www.helifreak.com/index.php)
-   Thunder Tiger GT5 FBL System (http://www.helifreak.com/forumdisplay.php?f=282)
-   -   GT-5 Gyro Touch Flybarless System (http://www.helifreak.com/showthread.php?t=323850)
falke398 07-20-2011 06:49 PM
GT-5 Gyro Touch Flybarless System from Thunder Tiger
Anyone heard or even tried one of these FBL systems?
http://www.thundertiger-europe.com/u...cs/8085_II.jpg
http://www.thundertiger-europe.com/i...=24&tt_news=85
http://www.infinity-hobby.com/main/a...rticles_id=226
http://www.rchelire_source.com/news-...arless-system/ remove the "_"
https://www.facebook.com/ThunderTige...89878731044154
I like the use interface...
falke398 08-05-2011 04:10 AM
something new:
http://www.rcmania.hk/Advertising/gt-5-ad.jpeg
http://www.rcmania.hk/wp-content/upl...1/07/gt5-s.jpg
falke398 08-05-2011 01:33 PM
infinity-hobby has some more information now.
price: $239???
http://www.infinity-hobby.com/main/a...rticles_id=235
1004ron 08-06-2011 11:18 PM
Looks good - German Tech.
http://www.heligarage.at/shop/index.php?a=19754
http://www.hangarone.co.nz/thunder-t...1af65c7b960a34
This product will be in stock on Tuesday 30 August, 2011.
http://www.youtube.com/watch?v=jK8d4JgJNe4&feature=player_embedded#at=235
nightrider 10-12-2011 10:48 PM
Has anyone actually used one? Keen to know more about it, very little info around.
I noticed revmax hobbies is selling them for $189, seems very cheap compared to other similar 3axis gyro's, does it mean they are a cheap fbl system and should be avoided?
dmulligan 10-13-2011 05:54 AM
That isn't much cheaper than the beastx which is a proven system. The beastx can be had for 199.
Sent from my GT-I9000 using Tapatalk
Trooper Sam 10-13-2011 12:10 PM
Tower has it now...
http://www3.towerhobbies.com/cgi-bin...6&I=LXBMEB&P=K
I'm keeping my eye on the reports, at least when there are some.
NitroAl 10-14-2011 11:14 PM
It's one of the best! http://www.helifreak.com/showthread.php?t=343454
JiriK 10-16-2011 01:56 PM
I´m installing a GT5 to my fbl MSH Protos.
At first that touch "button" felt a bit strange, but one gets used to it fast and then it is the best!
I guess there are not many who have experience with this unit..
I have a couple of problems:
1. When I connect battery to Bec, rudder servo drives to one end and stays binding until GT5 has booted up. Some setting wrong? I set travel adjustment so servo does not bind in normal operation. It does this only when connecting power.
2. Swash menu, trying to adjust collective and ail/ele pitch. Collective adjusts ok, if I move stick to full positive pitch and change the value, swash moves and pitch changes. Ail and Ele - swash tilts if I move stick but fbl unit adjustment does not seem to move it at all.
3. If I increase total gain (from transmitter) amount of swash tilting in ail and ele- directions increases a lot when moving the stick. So much that servos are binding.
Must be something I´m not getting right now..
I can setup microBeast, miniVbar and CGY750.
JiriK 10-18-2011 10:09 AM
A little follow up.
1. TT has seen this happen with some cheap servos. -> try a big brand ($$) servo.
Ok, so I tried with Futaba S9257. Problem is gone!
imho, cheap fbl controller should work with cheap servos.
Microbeast, Vbar and CGY750 all work just fine with that emax ES9257..
tracerbob 10-18-2011 01:54 PM
Originally Posted by Trooper Sam (Post 3318555)
Tower has it now...
This one has disappeared from Tower for some reason.
tracerbob 10-18-2011 04:41 PM
Yes, it does work. My PC at work was doing strange things. Wish we would hire a real IT person, Jeez. Anyway, just ordered one from Tower. We'll how it works.
Cheers
jockstrap 10-22-2011 04:29 AM
I received mine a few days ago from Revmax in Oz ($189AU - about the same US atm..) - looks really sweet..
Anyway - havn't had time to fit mine yet but a friend has one fitted to his new Raptor G4 and I had the chance to see it fly today doing some hard Smack 3D..
All I could say is "WOW"... this gyro is going to give vbar a run for it's money.. seriously..
It performed flawlessly over very hard stop maneuvers.. Tail didn't falter once and cyclic crisp and locked... piros were dead flat and smooth...
Can't wait to try mine now..
Euwan 10-22-2011 08:00 AM
Mine flew fine also after testing it however I am not sure about how to set 6deg of pitch on it as stated in the manual just keeps the same reading on my pitch gauge
Euwan 10-23-2011 06:21 PM
Ok just an update, I got everything working fine now and this unit is excellent I was flying a in really strong winds and it flew amazing. So easy to change settings love it. I have a mini vbar, beastx and align 3g in my opinion I think this unit flies a lot better, especially for the price and the amazing display.
There is a negative though it does take a while to master the double tap sometimes it works constantly for me and sometimes I find myself constantly tapping to get it to work.
jockstrap 10-25-2011 07:27 AM
Yea - I have the same issue with the double tapping but it works eventually - lol
test mounted mine on my tarot pro - cyclic was fine - had tail issues and it blew out doing a rainbow - had to rebuild my heli :( but in all fairness the tail on my heli is very sloppy so not fair on the gyro..
will play more and see how it goes..
Euwan 10-25-2011 09:43 AM
sorry to hear that man. Can you post the settings you were using for the tail and the cyclic?
jockstrap 10-25-2011 09:02 PM
oh - have changed it a bit. so don't have the exact settings..
Basically most were default except for about 10% higher gains..
Tail (HK15158A) was 1520 @ 333 - but my slider has massive slop.. has seen a few hundred flights by now and time for a replacment I think..
Cyclic (HXT900) 50hz or 60hz works fine..
Euwan 10-26-2011 04:17 AM
at default settings I found the heli really hard to fly hard. I had to turn gain up to about 80 on swash and about 70 on the tail
tracerbob 10-26-2011 07:02 PM
Has anyone noticed this?
1 Attachment(s)
Seriously
