HeliFreak
HeliFreak (http://www.helifreak.com/index.php)
-   mSR X (http://www.helifreak.com/forumdisplay.php?f=284)
-   -   Glue that holds in motor (http://www.helifreak.com/showthread.php?t=393549)
JCarter 03-09-2012 11:46 PM
I'm replacing my frame this weekend and just curious what the black glue is that eflite uses to hold in the motor. If nobody knows or has any suggestions for what they have used as a substitute that works, please let me know. Thanks
Liduno 03-09-2012 11:51 PM
I use automotive rtv silicone on my msr.
Flatearthman 03-10-2012 08:59 AM
a little dab of hot melt glue works and its easy to remove for motor replacement
RCNet 03-10-2012 09:20 AM
I just use Elmer's White Glue. This is what was recommended on the included DVD. It holds just fine, but comes off cleanly when it's time to change the motor.
timmyd463229 03-10-2012 07:37 PM
I use liquid electrical tape and it works well on other stuff
03Bugeye 03-10-2012 08:51 PM
what ever it is , it is garbage, my main motor has slipped out twice now.
Liduno 03-10-2012 08:56 PM
A sudden stop like in a high speed crash can put alot of force on the motor, It would take some thing more permanent like an epoxy to keep the motor from moving but that would make changing it or the frame a problem.
Dragonfly 118 03-11-2012 12:07 AM
Mine moved after a heavy landing.I tried ordinary silicone and it just melted with the heat.Then I remembered I had a tube of Shoe Goo and tried that.Just a small amount applied down the joint between motor and frame with a small flat bladed screwdriver does the trick,and it doesn't look unsightly.
The motor stays put now,and it will remove easily when required.:clappp
BigRHS 03-11-2012 03:12 AM
The liquid electrical tape works and holds up pretty well to the heat.
kfrisbee 03-11-2012 01:04 PM
I used 1 drop of CA at one of the corners. When I needed to replace the motor a little bit of CA remover did the trick
Liduno 03-11-2012 03:13 PM
If I tried to use ca on that I would probably end up gluing the whole heli into one solid part..lol I always get that crap every where I don't want it.
crashycanuck 03-11-2012 06:40 PM
i dont use any glue at all on mine. after the odd crash i have to give it a little push back into place, but you dont really need any at all.
Vandal996 03-12-2012 05:25 PM
Plus 1 on the hot glue gun. I use this to hold the motors, the connections for the tail and main motors and the main drive gear.
Flatearthman 03-13-2012 03:00 PM
+1 on it for the main drive gear
BigRHS 03-13-2012 04:07 PM
I thought about a little silicone once but was afraid I would get the gear or shaft a little out of balance.
What do you do, just put a little dab on the bottom of the gear and shaft to keep the gear in place ?
