Install pinjong on Esky engine?
I bought a new engine for my Belt today and I got a new pinjong in a separate bag. It is however impossible to get the pinjong on the engine shaft. It is an extremely tight fit.
What should I do? Thanks! |
Heat the pinion up with a cigarette lighter, then it will slide right onto the motor shaft.
I suppose it's a press on pinion. Don't forget to put some loctite.
| All times are GMT -5. The time now is 11:12 PM. |
