Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > CB100
CB100 Walkera CB100 Helicopter Support
Old 02-12-2010, 03:01 PM   #1
bobrains
Default Walkera Tail Motor Casing
Just curious if anyone else has had this issue. I've had tail motors on 2 Walkera helis (a CB100 and a 4G3) where the outer casing of the tail motor has come off completely. I can slip it back onto the motor and it still flys but can easily be slipped off at will.
I'm wondering if anyone else has had this issue and if so, if there is a way to reconnect it. I've looked through schematics and tried to look at the motor to see what may have held it there securely to begin with to no avail.
Any info is appreciated.
Bob
bobrains is offline        Reply With Quote
Old 02-12-2010, 07:57 PM   #2
john aeras
That is absolutly normal with walkera stock BL tail motors! You can't do much about it, other than upgrade to a 2.9g when the stock burns out!
Some people have a problem for every solution...
john aeras is offline        Reply With Quote
Tags
casing, motor, tail, walkera
