Old 03-07-2010, 11:06 AM   #1
SycoCell121
Default GY611
Do I have to use a futaba servo with the GY611 or GY601? I'm thinking of picking up a used one, but I currently run a JR 8700G servo on the tail. Will that be okay?
T-Rex 700 Nitro Limited Edition FBL - OS 91 HZ, Funtech B301 Pipe, AR 7100R, BeastX 3.0, Savox 1258 Cyclic, Savox 1290 Tail, Align DS 620 Throttle, Switchglow Pro, JR 9503
SycoCell121 is offline        Reply With Quote
Old 03-22-2010, 06:17 AM   #2
Al Miessner
yes
futaba only.. either 9256 or BLS251..
there is a secret menu that you can adjust the frame rate, however two of my friends tried and both set it back to default setting and bought the 9256. the gyro will not fly right
Flying Hard makes it fun (AnimAL)
GrandRC Team Pilot \, Team Ninja Pilot
Al Miessner is offline        Reply With Quote
Old 03-29-2010, 12:37 AM   #3
Jafa
JR and Hitech servos can be use on the GY 601 & 611 - works fine
It's the pulse width that needs to be changed in the secret menu
(Do this with the servo disconnected - then power off and plug servo in)
However, I think the 8700G does have a problem with the Futaba,
on initialization it goes hard over and binds - not good for it
The 8900 and others work fine
Rave 450 | Lepton | Logo 400/500/600 | Aeolus | Sceadu | Freya | Avant FX | Raptor G4
Gryphon field rep
Jafa is offline        Reply With Quote
Old 04-01-2010, 10:06 PM   #4
JAYHELI
+1 on futaba and 8700g servo. just ran into same problem
JAYHELI is offline        Reply With Quote
