Go Back   HeliFreak > R/C Electronics Support > Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion
Electric Motors, Gearing, Speed Controls, Gyros, Receivers, and Other Electronics Discussion Electric Motors, Gearing, Speed Controls, Gyros, Receivers and Other Electronics Discussion
Old 04-26-2010, 02:10 PM   #1
fransine
Default kontronik minijazz 15, helicopter mode
The minijazz ESC has a fixed helicopter mode (mode 4), which has governor enabled. About this the manual says:
"KONTRONIK recommends setting minimum RPM at 80% of full RPM"
I read that as the throttle setting should be 80-100%. Is that really true? I would expect it should be below 80% to give the governor some headroom.
The manual is here:
http://www.kontronik.com/images/stor...2009_09_15.pdf
t.
P.S. I can't find any specifications for the BEC voltage. Am I blind?
fransine is offline        Reply With Quote
Old 04-26-2010, 02:15 PM   #2
life2short1971
I would think because of the low torque of the small motor you need to keep the rpms up.it makes sense. The bigger the motor the more torque the more headroom you can have.
Scott
Trex 500 / /3026-1600/CC Ice75 /3G /Ds510's/Torsion 430 fbl's
Trex 450 pro/HK2221-8/ Ice 50 /HS-5065MG/325D's/Kbdd's
life2short1971 is offline        Reply With Quote
Tags
minijazz
