Go Back   HeliFreak > R/C Electronics Support > Eagle Tree Systems
Eagle Tree Systems Onboard data loggers, telemetry, and OSD support
Old 08-18-2011, 02:38 PM   #1
skunkworx
Default Plug-n-play ability?
I've been looking at getting a logger for a little while now. Can you pop and swap it from one heli to the next, or do you need to re-set it up for each model and reading values?
How exactly does it work? I see one port where it'll take the leads in and pass them on. Is it more of a pass-thru then? Where exactly do you hook it in at?
I also noticed on the V4 it has 100A and 150A versons. Is that the maximum reading they can do, or the maximum they can handle continuous/burst/etc...? Will it make more sense to just sit down and read the manual? I've never been around anyone who uses one besides in a CC ESC, so I'm not entirely sure how it's suposed to work. Thanks for any answers you can share.
Tim - Atom 500, 6HV, 3D+, eAurora
KBDD TEAM PILOT
Compass support/Nankin Hobby.com
--Si vis pacem, para bellum--
skunkworx is offline        Reply With Quote
Old 08-18-2011, 02:50 PM   #2
TheBum
Location: McKinney, TX, USA, North America, Earth, Solar System, Milky Way, Universe
Sorry, I never did get my v3 sent out to you to try out. Are you still interested? I was trying to locate my PowerPanel to send with the logger, but it is playing hide-and-seek with me.
As for how it works between different models, the software allows you to set up profiles. I believe you have to plug it into the computer and change the active profile each time you want it to go onto another model.
HeliFreak Support
Nankin Hobby Field Rep, Compass Support Team
Helis: Compass Atom 500 (V-Bar), Compass Atom 6HV (V-Bar), Blade 130X, Blade mCPX
Experience is something you obtain only after you need it.
TheBum is online now        Reply With Quote
Old 09-24-2011, 01:08 PM   #3
ahahn
I think the current limit is both, the max they can read, and the max current they can handle.
To be honest, since I installed my ICE50, I haven't really used the ET much.
ahahn is offline        Reply With Quote
