Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Odin and 3D+
Odin and 3D+ Compass Odin and 3D+ Model Helicopter Discussion
Old 09-25-2011, 06:36 PM   #1
RotorHeadKen
Default Starter Bearing Block Orientation
On my old K3D, the manual states that the shallow gap on the starter bearing block faces the front of the heli. Of course, the 3D+ manual is completely silent on the issue...
So, shallow or deep gap towards the front?
RotorHeadKen is offline        Reply With Quote
Old 09-26-2011, 06:01 AM   #2
Cullen Colapietro
I would go with the orientation that results in the proper gear mesh. Unfortunately, I can't say which that is.
6HV|Warp 360| Compass Models | Prostar Hobby | MKS | EP Buddy | Team KBDD
Cullen Colapietro is online now        Reply With Quote
Old 09-26-2011, 08:12 AM   #3
RotorHeadKen
I did it both ways and could not tell which way was better. Does anyone else know the correct orientation?
Old 09-27-2011, 01:19 PM   #4
Down Low
Shallow slot towards the front on mine. Perfect gear mesh.
Airtronics SD10G, SK540, OS.50 Hyper (possibly tweaked a little)
Synergy N5c
MAAC #85462
Down Low is offline        Reply With Quote
Old 10-03-2011, 01:36 PM   #5
RotorHeadKen
In case anyone was wondering, I installed the shallow gap toward the front, and the heli did not blow up. Everything appears OK
Old 10-03-2011, 05:33 PM   #6
Down Low
Synergy N5c
MAAC #85462
Old 10-04-2011, 09:03 AM   #7
belcom
Last time I took it out and put it back in, the pinion was very tight against the main gear when installed the wrong way. Once changed the direction it was all nice and smooth and good gear mesh. Not sure which direction it was as it kind of looks similar on either side. One more observation is that you will only notice this when the main shaft is installed.
Compass 7HV, SAB Goblin 700, Minicopter Diabolo, Mikado Logo 600, Synergy E5
RCHeliCanada.com - Compass Model - Synergy - Scorpion - MKS Servos - YGE - Kontronik
belcom is online now        Reply With Quote
