Go Back   HeliFreak > R/C Electronics Support > Thunder Tiger GT5 FBL System
Thunder Tiger GT5 FBL System Thunder Tiger GT5 Flybarless Electronics
Old 12-06-2011, 04:57 PM   #1
growmaster4
Default dx8 telemetry
Is there any way to use the dx8s telemetry unit while using only satellites with the gt5?I don't really want to run the whole receiver setup just for the telemetry.if not,hopefully we can get that in a update
Trex 500 12s vbar I2 bling
Furion 600 12s vbar I2 bling
trex 700edl vbar 12s I2 bling
Tdrex 800e 12s vbar I2 bling
Bank account EMPTY
growmaster4 is offline        Reply With Quote
Old 12-28-2011, 10:40 AM   #2
J-S-Q
The TM1000 telemetry module only requires a power source in order to operate so as long as you can provide that then you can have telemetry. There is a spare channel on the GT5 (which you can use for a governor for example) that you could use as a power source for the TM1000. If you are already using a governor then you would need to connect the TM1000 with a Y cable (I've not tried it myself but I would think it's probably best to remove the signal wire from the TM1000 connector in this situation just to avoid any unexpected complications).
What you will not have is the signal strength/antenna holds/fades telemetry information. The only way you can have this is if you use a full size receiver. All the other telemetry info (rx voltage, temperatures, rpms etc) will work fine with this method.
J-S-Q is offline        Reply With Quote
