| 600/600 PRO Aftermarket Upgrades and Mods Align T-REX 600/600 PRO Aftermarket Upgrades and Mods Support |
#101 | ||
Its extremely hard to get a good photo of this showing what I mean, as the camera doesn't get into that tight spot and looses focus with the heli assembled and main shaft\tail gears spinning..but its although the main shaft and the tail umbrella gear shaft are a fraction "too far" apart. I tried to push the tail boom mount further up (to push the tail drive gears closer to the auto-gear), but it only goes so far.. The new autogear and tail drive gear the teeth fully mesh into each other, a much much closer fit further up the "teeth", like a zipper almost. Anyway, lot of people seem to be using them without issue and agree the superman burst of headspeed is the cause of the shredded gear in this instance.
Gaui EP550 CF PRO - DS610's, 6100T\6100G Combo, 6S - 3600 Nano-Techs! Trex 600EFL PRO - Vbar Mini,DS610's\DS650,CC 80HV Ice, 12S - Turnigy 3600 E-flite Blade450 3D - New RTF kit with DX6i - competition prize To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Spektrum DX7 Mode2, Phoenix Sim. |
#102 |
Sorry to barge in here, i have the 600 pro also , i have been running my HS at 2200 with the V-Bar, but i can't get my tail to spin faster, i have the Torque 9188 servo , and i have my yaw rate set at the max 121 in the V bar, my limits are at the max without binding, and still the tail won't go faster, ,,
i really like doing piro flips but i cant because the tail issue,, anyone have a solution that may help ?![]() |
#103 |
Hi Ball link. You are not barging in.. Sharing info is what it's all about. First off if you are going to try piro flips with 2200 HS and a stock tail ratio, it will blow the tail out and crash. 2350 is the minimum I would attempt that at. second your piro rate probably seems slow due to your tail being slow. Either do the the tail ratio mod or up the head speed. I am running the VBAR also and a HS of 2500. My yaw rate is set at 108 and its fast.
Chris |
#104 | |
If your piro rate is the same to the left and to the right, then I would suspect some radio setup issue (dual rates), rather then a physical limitation.
Goblin 700, TT X50e, Synergy E5-600, Fusion50, Trex 700e HeliDirect, GrandRC |
#105 |
Thanks guys for the help,, i think i found out my prob,, first of all i have the DX 7 , not sure if different radios' make a difference but i did like i allways did when i had flybar setups,, and adjusted my travel adjustment (rudder) about 10 clicks both left & right and the tail is fast now
, i guess it takes a little poking around here and there to figure out this flybarless thing,, but i am starting to like it the more i fly this bird,.I still fly my nitro flybar 700 , but this 600 is just madness,, i like |
#106 |
I just stripped my gears also. At 2100 rpm I was doing some upside down tic tocs and my tail blew out. I then heard a funny noise and so I landed the heli in time to inspect. Auto gear looks to be fine, but the umbrella gear set is wearing out.
I am now switching back to the stock setup. I an reluctant to put 105 tail blades due to the risk of the blades hitting eachother. |
#107 |
Bummer. With the 4.5 ratio the gears are running at a higher RPM, so it seems reasonable that they would wear faster as well as be under greater stress.
With 105's and 600mm blades (not 603mm) I've had hundreds of flights without issue. Lots of other guys running 105's and I have yet to hear of an in flight case of the tail blades touching. I still think 105's @ 2250-2300 gov'd is the best setup. Less vibration, less gear wear. Mine has been a real workhorse.
#108 | |
I'll probably just get the 102's from KBDD. What do you think? Thanks OTS for all the great advice! |
#109 |
#110 | |
Try a full collective backwards inverted hurricane at 2200 and drop the tail into a full collective inverted funnel. Be ready for a 90 degree blow out. A weak tail is fine when you know the limit. We all love the stock mcpx, but it requires great collective mgmt to 3D it well.
#111 |
I need help on this drive gear stuff. Is the the H60199 the stock gearing or is it 4.5:1 ratio?
https://www.readyheli.com/H60199-131...2_p_38710.html Or do I still need to use the parts listed in the first post to do the speed up? Signed, So Confused |
#112 |
Mod .8 gears are the lower tail speed ratio. What you're looking for are the tt gears used in the original 600e. You'll probably find that under a 600 esp section. The auto gear would be the "updated" hub that is not mod .8. The A part number if I recall. Most of this info should be on the first page. (ps, the older ratio gears come in 3 packs)
Resident Mad Scientist E5-S KDE 600XF / 600N 55HZ 450 Pro V3 / Mod 130x / mCPX BL Mike D--AwesomeRC Hobbies |
#113 | |
I have not had the weather to try it yet but I'm sure it will hep. john |
#114 |
Many folks have seen that. I guess Align figured they could get away with farther away gear lashing with a bigger modulus. Either way, a few folks including myself have slotted our frames only about a mm or 2 to get better mesh with both the .6 and .8 gears. I recently did up a whole test about the subject in a thread about stripped tail gears. The TLDR of it all was that under abnormally high load testing, I could blow out both gear mods with the stock mesh, but only heavily wear them when manually meshed.
