| CJY Total-G FBL System Curtis Youngblood Total-G FBL Flybarless System Software and Hardware Support |
My Rave 450 flies ok but randomly shakes, any idea how I can get it fixed? Is it the gyro tape, I am strapping the Total G down with Velco at the moment, may remove the Velco tomorrow and try.
What type of shake ? Aileron or elevator?
Sent from my iPhonings
7HV,EL Brute, HW120 hv, bls 451,251, SK540 Warp, mks92a, ds525,hw40pl, sk540 Lynx team pilot |
#3 |
Aileron, side to side I think a bit front and back
#4 |
Sometime a wobble or shake can be caused by too low a head speed with the head damping being too tight.
What is your headspeed? Have you recently changed out your head dampers? Which head dampers are your using? Are they glued in? What kind of gyro tape are you using? How many layers? Don C |
#5 |
The wobble is gone once I replaced the cheap Align wooden with the Radix blades, thanks guys
#6 |
Hi guys, im having similar problem with my rave 450, but mine shakes when i give rudder input, what could it be?
Thanks Mike |
#7 |
Did you change anything?
Was this after a crash? I would try lowering the tail gain first. If that does not help then start going over the tail assembly. Pop the link off the rudder servo and check for binding - try moving the control rod back and forth. Check for slop at the tail rotor grips. Let us know Kevin
CYE Field rep http://curtisyoungblood.com/ Ballistic 700,Ballistic 635, Rave ENV Nitro, Rave 450, TotalG, MP7, Radix Blades |
#8 |
Check if your TT is split.
Easy way to tell is hold the head and try to turn the tail. If there is any spring feel too the tail, your TT is broken/partially split. |
#9 |
Extra3D any results yet?
