Go Back   HeliFreak > R/C Electronics Support > CJY Total-G FBL System
CJY Total-G FBL System Curtis Youngblood Total-G FBL Flybarless System Software and Hardware Support
Old 03-01-2012, 12:43 AM   #21
husafreak
Thanks bro! I am going to try and get that firmware upgrade.
BL MCPx/Blade 130X/Rave 450 Vbar/Protos 500 Vbar//Logo6003D Vbar/Rave ENV90 ARBX/TDR Vbar
husafreak is offline        Reply With Quote
Old 03-01-2012, 06:52 AM   #22
mystar60
Husafreak, as Marshall said creep up on your FC gain. At 52 it seems it may be a little low. I am at 60 and it seems very crisp.
I was able to meet up with Marshall at IRCHA and tweak my settings, the increase in gain made a big difference.
Kevin
CYE Field rep
http://curtisyoungblood.com/
Ballistic 700,Ballistic 635, Rave ENV Nitro, Rave 450, TotalG, MP7, Radix Blades
mystar60 is offline        Reply With Quote
Old 03-01-2012, 10:11 AM   #23
husafreak
I remember there was an issue in the beginning where gain values were different depending on whether you used the radio or the gview (or computer) to set gain. I believe that was fixed in the first update. I have been through this process before but I will do it again. I PM'd Marshall to see about getting the latest update.
Old 03-08-2012, 07:17 PM   #24
mattsergo60
When will the Fc11_3c7 be released?
2 -JR VIBE 50's---HK 600 GT---HK 450 PRO
FBL-JS TZ V2 50 TT---FBL JS TZ V2 90 w/ TOTAL G-- JS TZ V2 (belt)---Bell 222 FUSE with modified Voyager mechanics running a 6 cell LI-PO. and FBL !
mattsergo60 is online now        Reply With Quote
Old 03-08-2012, 09:48 PM   #25
CF_Machete
hopefully soon, I want to ditch my extra wires for an s.bus cable and cut the crap.
fbl furion 6, fbl gaui 200 v2, FBL Stretched Align 450 pro V2, fbl t-rex 500, fbl beater 450...and some planks.
CF_Machete is offline        Reply With Quote
Old 03-22-2012, 05:01 AM   #26
mahbouni
Is there any info on the next firmware release? Also I can't find Curtis's daily blog. AllMyRC seems to have disappeared.
Logo 700 Synergy E7 Logo 600 Logo 500 Protos 500 Mini Protos
mahbouni is offline        Reply With Quote
Old 03-22-2012, 10:58 AM   #27
band
Contact Curtis by e-mail to get the file.
band is offline        Reply With Quote
Old 03-22-2012, 02:15 PM   #28
mattsergo60
Done, got it ,thank you
Old 03-23-2012, 07:27 AM   #29
mystar60
mahbouni - the AllMyRC website has been down for a while along with the blog. No news when it will return
CYE Field rep
Old 12-22-2012, 12:07 AM   #30
Gedexas
Can anyone send me the Total-G firmware files or do I have to get them from Curtis for some reason. Specifically I'm looking for a version newer than fc11_0.
Gedexas is offline        Reply With Quote
Old 12-22-2012, 07:02 AM   #31
mystar60
Email Curtis for the latest version. I have version fc11_3c7
CYE Field rep
Old 12-22-2012, 10:48 AM   #32
Gedexas
I'm going to try and get the fc12 as well, hopefully it's not a secret version, because if it was, I would not know about it.
