Go Back   HeliFreak > R/C Simulators Support > Reflex Flight Sim
Reflex Flight Sim Reflex Simulator Talk
Old 02-28-2011, 09:42 AM   #1
ZephanRC
Default HELP: Reflex XTR and Win7 Install???
I have had Reflex XTR for years on my old WinXP computer and have now gotten a new Win7 computer.
How do I get Reflex XTR installed on my Win7 computer. I have the original Reflex XTR CD and try running the setup.exe, but it fails on installing the "dongle" driver and the program does not install.
Is there an update for Win7?
Trex600N & Trex450SE. Dang! Another Radio Glitch!
ZephanRC is offline        Reply With Quote
Old 02-28-2011, 05:07 PM   #2
darryl123
try to copy the reflex folder from the old xp computer to the new one and then you should be able to run the program by opening the folder and click on the reflex icon in that folder. directions are on there website.
raptor 90 fbl
raptor 50
raptor x50 fbl
raptor e620 fbl
darryl123 is offline        Reply With Quote
Old 03-01-2011, 03:01 AM   #3
tj69
You can get update here..
http://www.simwerk.de/cms/images/sto...ETUP_V5031.exe
Mini Titan E325 SE, Trex 600LE, AURORA 2.4GHz AFHSS, Phoenix RC, Reflex XTR2.
tj69 is offline        Reply With Quote
Old 03-27-2011, 02:15 PM   #4
Bisso
I tried the suggested link, both EN and DE version, only the RMK is installed, I don't get any exe for reflex itself..
Anyone got the same problem?
Bisso is offline        Reply With Quote
Old 02-02-2012, 09:30 AM   #5
CousinLarry
I installed it on my Win 7 laptop using the original Reflex CD..
You **MUST** install the program in compatibility mode.
Insert CD, browse to the CD using windows explorer, in the root of that CD is setup.exe. You have to right click on that file, and choose properties. Under the compatibility tab, check off "Run this in compatibility mode for Windows XP service pack 3"
Then hit OK. Then right click on the setup.exe file again, and hit "Run as administrator"
You should be able to install with no probs. Once installed, find the icon for Reflex in your program menu. Right click on the icon, hit the compatibility tab, and make sure "run in compatibility mode for Win XP" is selected.
Should be good to go!!!!
CousinLarry is offline        Reply With Quote
Old 03-23-2012, 02:42 AM   #6
NZ_Nitro
wont work missing dll and the dll wont work with windows 7
NZ_Nitro is offline        Reply With Quote
Old 03-28-2012, 12:21 PM   #7
CousinLarry
I dunno then. Works for me.
Old 01-05-2013, 04:19 AM   #8
elane17
Default win vista
Just installed the above link after download and it appears to work on vista with blue dongle .I will now try to install on my win 7 machine and report back after I attempt to install .
I have been trying to install this program off and on for about a week or so,I have a xp machine that i installed reflex on but when I copied it to a flash drive it would not install no matter what configuration i tried ie admin compatibility mode nothing at all worked so I am happy to report this is a good download and it seems that all the files needed are intact .
Eric L.
elane17 is offline        Reply With Quote
Old 02-11-2013, 10:45 AM   #9
Monodrive
Hi I also tried the thread above, but then it only installed the Reflex Monitor and nothing else. Then I run the original cd that works well also, but in the end of installation it ask for usb joystick ( IVOL) connect it but no driver will install, the computer das not recognize the joystick.
This I bought when xp was installed and is ver. 5.03 something for the Realflex XTR from 2008 approx. Joystick is the original reflex XTR iVolbut no driver will install. Please does anyone know, I found this on WEB but please help.
Monodrive
Monodrive is offline        Reply With Quote
Old 02-11-2013, 11:04 AM   #10
Monodrive
Monodrive
