Old 04-27-2012, 03:55 PM   #1
flashhh12
Default 500pro frames question
I was wondering, if I can swap my frames on my 500esp to the 500 pro frames..?
I want to upgrade my 500esp.. i know i can swap my electronics, that wont be the issue.. but like the tail mount and skid mount, head block and etc..
Can i buy the Pro frames only, or will I need to upgrade some other stuff
Please let me know..
Thank you
flashhh12 is offline        Reply With Quote
Old 04-27-2012, 04:01 PM   #2
flashhh12
Looks like I might only need the battery tray and Bottom Plate correct ?
Old 04-27-2012, 04:18 PM   #3
Maypole
Anything that fits between the frame halves will need to be replaced because the pro frameset is narrower. Main shaft bearing blocks, tail boom case, rx trays, anti rotation bracket, braces, etc.
Doable but an expensive pita imo.
Nano CP X, mCP X BL, 130 X (Love the little ones)T-REX 500 Efl Pro DFC
Phoenix Sim, DX8, Gibson Les Paul, AMA #987871
"If a law is unjust, a man is not only right to disobey it, he is obligated to do so." Thomas Jefferson
Maypole is online now        Reply With Quote
Old 04-27-2012, 04:50 PM   #4
flashhh12
Ohh, i didnt know it was narrower, Yeah not it involves a lot more components..
Well for get that then.. unless I have a major crash then I would prob just get a kit..
Thanks for that info.
Old 04-27-2012, 04:54 PM   #5
tomd27858
You would be much better off to buy a combo kit and sell off what you don't need. You will find if you do a part out list and assign dollars to it you will be much better off and won't do too bad.
Team HeliDirect
Flying Align - Powered by Pulse
tomd27858 is offline        Reply With Quote
Old 04-27-2012, 05:28 PM   #6
flashhh12
Yeah, sounds like the best way
Old 04-27-2012, 06:45 PM   #7
helicopter1
What if someone buys the pro frames and used all his existing in-between frame parts will that work out o.k.? Sure it will not be narrow like the pro is, but do all the screw holes line-up with the older version in-between frame parts?
helicopter1 is offline        Reply With Quote
Old 04-27-2012, 07:08 PM   #8
krauley
I was thinking the same thing but also if you widen the frames will pro canopystill fit because i believe the esp canopywont fit pro frame.
UH-60 EXI 500 DFC/3GX v5.0 ICE 75 Bec Pro w/4 blade main & tail rotors
Align trex 500DFC Pro w/ 3GX v5.0 Align trex 150X
Oxy 3 Tareq Edition AR7210bx Edge lite 50 Kst 215's
PL6 w/Bump Controller-24v PS DX8 V2.06
krauley is online now        Reply With Quote
Old 04-27-2012, 10:05 PM   #9
flashhh12
What if someone buys the pro frames and used all his existing in-between f rame parts will that work out o.k.? Sure it will not be narrow like the pro is, but do all the screw holes line-up with the older version in-between frame parts?
I dont think this it will work because the tail boom and battery mount wont fit right
Old 04-27-2012, 11:47 PM   #10
Deet
IT WONT WORK
Dave
Goblin 500, Vbar, BLS153, BLS251, Kontronic Jive & Piro
MutliWiiCopter Scarab Stealth Armour,Scarab Stealth Reconn V3, Scarab TriiKopta, Scarab Octa, Scarab Vampire
Deet is offline        Reply With Quote
Old 04-28-2012, 08:34 AM   #11
tomd27858
Deet is right. Buying a combo and parting out your electronics is the way to go
Team HeliDirect
Old 04-28-2012, 02:46 PM   #12
helicopter1
So, you are saying that the boom mount holes and battery mount holes from the ESP don't match with the PRO frame holes and I can't use all my old 500 ESP wider parts on the newer pro frame halves?
Old 04-28-2012, 06:20 PM   #13
Deet
NONE of the frame components will work, they are all completely different
Dave
Old 04-29-2012, 05:32 PM   #14
helicopter1
Thanks for clearing it out.
Old 04-29-2012, 07:23 PM   #15
Steemo
Yeah the re-design was quite comprehensive.
They are actually completely different helicopters designed to be set up in a very different way, they just happen to share a few parts such as boom, spindle and auto gear etc.
T-Rex 700E Pro DFC HV Brain | T-Rex 600E Pro DFC V-Bar Silverline 5.3 Pro |T-Rex 500 DFC Pro mini V-Bar
T-Rex 450L Dominator | JR DSX9 9503 Mode 2
Steemo is offline        Reply With Quote
Old 04-30-2012, 05:42 PM   #16
densis
just pick up a pro kit on ebay without electonics
1: align trex 500EFL Pro DFC AR7200BX
E-Flite MCP x V2.0
Spektrum DX8 / DX18 Phoenix Sim
densis is offline        Reply With Quote
