| Avant RC Nitro, Electric and FBL Avant Aurora, Electric eAurora, RigidCore Flybarless Head, Avant EFX and Avant FX Helicopter Support |
What batteries are you guys with Aurora Es running?
What's the optimum size for mild 3D and good run times? Thanks!
“One way to make sure crime doesn't pay would be to let the government run it.” RR TREX450XL, TREX450SE, TREX600E, TREX 600 HFEX, TREX500, Vibe 50 (Professional grade pretzel maker). |
Not sure what the optimum size is, I think a lot of people run 4400- 4500 mah batteries.
I run 5100mah 45C Voltz batteries and Gens Ace 5300mah batteries. The Voltz have to be as far back as I can get them to balance the Heli but the Gens Ace batteries can be moved forward slightly. The Avant is fast with these batteries, I'm probably losing a tiny bit of pop using a slightly heavier battery but I don't notice.
Jim Trex 250 ---- Trex 450 Pro ---- Trex550 FBL ---- Trex 700E FBL ---- Avant Aurora 90E ---- Goblin 700 Keep it off the Ground....but just barely
#3 |
It all depends on flying styles and set up's. Myself I run 5000 mAh packs with a Scorpion 4525-520LE, and can squeeze out 4 min depending on how hard I push the heli. I have seen others get 5+ minutes on 4400's flying mild 3D, and FF..there is also a physical size limitation on the Aurora of what batteries will fit without hitting the canopy, which is posted on the Avant Forums. You can view this if you are a member of the forums.
Avant RC Factory Pilot / A Main Hobbies Customer Service. Representing: Team Avant,A Main Hobbies, YS Engines, Edge Blades, Thunder Power RC, Scorpion Power Systems, Spektrum RC, Aerospire RC, Insane Canopy, Castle Creations |
#4 |
Thanks Jason. I picked up two turnigy nano 4400 packs. They are 45c to 90 c. And quite hefty. I'm just a sport / mild 3d flyer. So five mins would be fine. Don't want to get too heavy.
#5 |
Apologies in advance for hijacking. I have 16 pack of 3s5000mah 45c which I pair in series to make it 6s5000mah for the rex600. ANy chance if I may pair two pairs of 6s5000 to make it 12s5000 to fly this baby? I m v worried of the internal resistance. I m using 6mm conectors btw. Many thanks for any advice rendered. Grateful.
Trex700N LE, Trex600ESP,Mini-Titan & Trex250SE Feeling of Hover at (28/12/2009) - PRICELESS! Biggest mistake - selling my Beam...crap! |
#6 | |
#7 |
I Just ordered 2 pairs of nano techs 4000mah 6s for my avant E.
They fit fine but look to be a little small/light. Hope this are not to light for the avant. When in the front space of the battery compartment heli looks to be in balance. Have not fly them yet... any one who already did/try? are 4500 nano's a better choose? |
#8 | |
Wow! Jason Bell reverting to my query... ![]() Yeah, I m a lil concerned about the internal resistance of the lipos as well. The series-connection cable that I m using is already pretty short (prob 100mm) I was actually contemplating to do without the cable and to connect the batts directly. I just can't wait to get my lil hands on the aurora, it just oozes class... ![]()
#9 |
I personally prefer a lighter helicopter, and so I choose the ThunderPower 4400mAh packs. By my calculations, you save about 16 ounces (one full pound) by using the smaller pack.
There is a law of diminishing returns with larger and/or smaller battery packs. Using larger packs, the helicopter weighs more, and so you consume more milliamps per minute--but since your packs are larger you have more milliamps to burn. Using smaller packs, the helicopter weighs less, so you consume fewer milliamps per minute--but since your packs are smaller you have less milliamps to burn. So when it comes to flight times, it's almost a tie. Which battery size is better? There are arguments either way. On windy days a lighter helicopter is better. On calm days a lighter helicopter is better. And on and on.... But one thing is for certain: When you're trying to autorotate an identical helicopter with identical blades, but one helicopter weighs 16 ounces more than the other, the lighter helicopter will hang longer. This is why I prefer to use the smaller batteries. But to each is own...
Avant RC Scorpion Power Systems ThunderPower RC Kontronik Drives |
#10 |
oke don't buy the nano's 4000mah for the avant, they are to light (weight). Power is not the problem, got a lot of pop!
Can't get the hell balanced, it has to short weight in the front, and i can't move them more to the front. gonna need to buy heaver one's. i'll give the turnigy 5000 25c a try |
#11 |
I'm running the nanotec 5000mah.. 45C-90C..
I've push it all the way to the front.. It's still tail heavy.. Am I the only one that has this problem or I've not done something right quest
life is not the amount of breath you take, its the moment that take your breath away |
#12 |
that's strange...
i gonna buy the turnigy 50006s 25c, they are almost the same weight as your nano's. Hope they will balance right? Does anybody use this lipo's in the avant? with the 4000 nano'c it's almost in possible to fly |
#13 |
i got the 5000 25c turnigy lipo's and they fit perfect. Little tight but the upper en lower part are vertical so when they puff a little it will still fit (i hope)
Balanced perfect (just put them in the most fronted position) Fore normal flying i think they are great and cheap (around $130,- a pair) |
#14 | |
For battery slot sizes see this thread in Avant RC
http://www.avantrc.com/support/showthread.php?t=1203 Quote:
#15 |
I have turnigys and although the dimension of the actual battery fits fine, the leads are soldered so that the wires petrude a bit higher then the battery. Is there a mod to make this work, would you try and bend the wires? or maybe make a notch in the frame?
Avant E-Aurora FBL Vbar 5.3pro / Trex 450 pro vbar 5.3pro/ Velocity50 Vbar 5.3pro / Trex 600efl PRO Flybarless vbar/CC HV80 / Outrage 550 VBAR5.2Pro/ICE100 Heliflightcenter Team Pilot |
#16 | |
#17 |
I tried rotating the battery but that side is larger and doesnt allow the battery into the framer. I like the idea of cutting out a notch, its either that or make the entire width larger so the battery can be turned 90 degrees
#18 |
quite a few post of guys buying the nantechs. I just wondering how those batteries are doing because I have not had good luck with the nano's. Mine have puffed at around 15-20 flights
#19 |
Sorry to dig up a dinosaur, but I'm at a fork in the road over pack size right now. I have Gens 5300's which work great, but are just simply not going to fit well enough for my liking. I realize I can run higher headspeeds with them and retain a lot of flight time, but I think I'm happier with lower rpm for now and lighter packs. I tried Turnigy 5000 25C's and they were pretty tough to get in and out of the machine but the weigh seemed nice and had more than enough power for my kind of flying.
Anyway, I've been eyeing the TP packs in the 4400-5000 range and also Pulse 4400-4500's. Has anyone checked these to see how they balance? I'd prefer to stay upwards of 4600-5000 if I can since they would give me the same flight times but I want them to fit under the lid too. Darn canopy is hard enough to don/doff as it is!!! Any words of wisdom would be great. Also, any other brands to consider would be nice too. I'm not terribly shy about experimenting but I also like the idea of only needing one pair which is why I was considering the TP's to begin with.
Tim - Atom 500, 6HV, 3D+, eAurora KBDD TEAM PILOT Compass support/Nankin Hobby.com --Si vis pacem, para bellum-- |
#20 |
Still flying TP 4400mAh packs here.
