| Flybarless Helicopter Systems CSM Cyclock, Helitronix Multi-mixer, Spartan AP2000i, Firmtronix Digimix-3, Gyrobot, SK360and AC3X |
Hello folks,
I'm thinking of investing in a Tarot FBL head and ZYX gyro for my 450 pro clone. I'm currently using inexpensive (yet reliable) MG90 servos (analog) and a Emax digital tail servo. Has anyone successfully used these cyclic servos with a FBL head? Would I be better off going with digital servos (preferably still inexpensive)? Thanks! |
Here's the servos I'm using and they work good.
http://www.e-fliterc.com/Products/De...rodID=EFLRDS76 |
#3 |
I'm using my original Hitec 65MG servos which are analogue and very similar to the (far cheaper) MG90s and all seems fine.
#4 | |
I have also tried a number of cheap digital servo's. The Corona DS-929MG seem ok,but develop some slop with the gears after a while-this seems to happen a lot with the low-cost MG servo's. I just ordered a couple sets (6) Solar 12g MG servo's from Hobypartz which just came back in stock. I have also tried the D922 MG servo's from HK,& they are inconsistant quality. Have had a couple DOA out of the box,& a couple that needed the gears centered so it would work. The ones that did work were good,& have lasted many flights. |
#5 |
+1 I'm using TP MG90 on cyclic as well and work fine but yeah definitely have to lower the gains toget rid of the wobbles.
Check out my Night Blades Blog here on HF |
#6 |
I am using MG90S cyclics on two 450s with the CX3X and have found that if you move the balls in on the servo arms to the 3rd hole in ( ~11mm) you can raise the gains. One is at 30 main gain on pitch and roll, the other at 40. I run the P at 70, I at 75 and the D at 20 in the advanced menu. Works for me. The MG90S is a bit weaker but faster than the MG90.
I also am running some Henge 922's on a ZYX and some HXT900's on a CX3X with the gain at 40. Both work pretty well. I also just ordered some Solar digitals. I am hoping the Solars will work well with the ZYX and CX3X. Terry |
#7 | |
http://www.hobbypartz.com/33p-solarservo-d654.html I have been thinking about getting some of those for my Blade 450 3D with the ZYX and would love to hear what you think about them when you get them.
Tarot 450 Pro V2 FBL - Blade mCP X - Blade 450 3D FBL |
#8 | |
#9 | |
I bought these mostly as spares to try out later (got them along with a lipo order),so will have to try them out soon to see how they perform I took a few photo's for comparison,in order top/bottom are :Henge MD922 MG -T Pro MG90 -Power HD 2216 MG - Solar D654 MG |
