Go Back   HeliFreak > R/C Helicopter Support > Hirobo Nitro Helicopters > Hirobo Electric Helicopters
Hirobo Electric Helicopters Hirobo Lepton EX, Quark and other Electric Helicopters
Old 06-04-2012, 01:11 PM   #1
400 flyer
Default lepton motor ?
can i use this motor ?
http://helidirect.com/scorpion-hk-32...is-p-25535.hdx
right now i have a hyperion z3025-08 (970kv) motor and not sure its the right one for this heli.
if i can use this hyperion motor what pinion sould i use?? right now i have a 24t and a 22t pinion.
i also have a hacker a30-12xl (770kv) motor. what would be the best motor to use? and what size pinion to go with?
o im useing 4cell batterys running a cc ine75 esc.
2-evo 50's>1-sdx>hawk pro bell 222 /3g/rjx>evo90>freya 70.
trex500esp, scorpion/ ice 75/ 3g/rjx>hirboo embla 450 fbl,ice50,>lepton ex
2 bl mcpx's
futaba 8fgs,,dx7,,phoenix v3.0r
400 flyer is offline        Reply With Quote
Old 06-20-2012, 11:34 AM   #2
400 flyer
anybody ??
2 bl mcpx's
Old 06-21-2012, 06:09 AM   #3
gratefulfrog
Hi,
Sorry to have missed your post earlier.
Is there a problem with the 970kv motor you have?
Ideally you should use lower kv rating to run motor near 100% throttle, but that's not absolutely necessary. Just more efficient.
check out the head speed calculator and play around http://heli.dacsa.net/calcv3/Default.aspx
I run a Strecker 1150KV motor on 4S 20T but have to keep the throttle down around 60%. I don't do 3D.
Mainly don't worry about it!
Ciao,
Bob
gratefulfrog is offline        Reply With Quote
Old 07-21-2012, 05:24 AM   #4
Jafa
That motor should work fairly well - with a 22T pinion
Either use the ESC governor or a flat 85%~90% throttle curve
Rave 450 | Lepton | Logo 400/500/600 | Aeolus | Sceadu | Freya | Avant FX | Raptor G4
Gryphon field rep
Jafa is offline        Reply With Quote
