Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 60/70/90
Thunder Tiger 60/70/90 Raptor 60/70/90 Helicopters
Old 08-08-2012, 03:34 PM   #1
camarohrod
Default Flywheel question
I have a raptor 60 with an os70, my flywheel/fan keeps coming loose and binding everything up, do I need loctite on the flywheel nut? Or is there a special way to keep that thing from coming loose?
camarohrod is offline        Reply With Quote
Old 08-08-2012, 05:56 PM   #2
ticedoff8
#1 - you need to use a crankshaft lock when you tighten up the flywheel. I don't tighten more than "extra hand tight". No Channel Lock pliers needed - just a towel wrapped around the fins and the crankshaft locked from the rear.
#2 - Yes, add blue Loctite to the crankshaft threads before you screw on the flywheel and then a little more on the "prop nut" (flywheel nut). Again, make sure you have a crankshaft lock when you tighten up the nut
I have OS 91 & YS 91 and use this technique. I have never had a flywheel come loose - even with a broken rod that stopped the engine from full throttle.
ticedoff8 is offline        Reply With Quote
