Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger 60/70/90
Thunder Tiger 60/70/90 Raptor 60/70/90 Helicopters
Old 08-12-2012, 07:10 AM   #1
phillhague
Default PV0149 bevel gear
Does anyone know if there is a replacement available for this item PV0149 as they appear to be scarce over here in th UK, I have seen PV0149-1 but that is listed for the 50 size heli or does it fit the 90 as well ? Any input will be appreciated.
phillhague is offline        Reply With Quote
Old 08-14-2012, 04:23 AM   #2
phillhague
Default PV0149-1
Got one of the PV0149-1 from my local heli shop, looked at it and input gear is exactly the same as the one in PV0149. Output gear has a thicker shank diameter where it slides over tail shaft and is drilled for a retaining pin at both ends, looks like this is because the X50 securing pin is at the other end of the gear compared to the Raptor 90. Anyway it fits with no clearance problems.
