Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > Multiplex FunCopter
Multiplex FunCopter Multiplex FunCopter Helicopters
Old 08-28-2012, 11:24 PM   #1
retroman
Default Battery
Let me re phrase my battery question. What is the strongest battery you could safely use in the Funcopter ?
retroman is offline        Reply With Quote
Old 08-29-2012, 07:38 AM   #2
AtTheCross
sorry not sure I understand, strongest cell wise? Stock ESC would be 3s.
Stroungest in other battery parameters like in C unlimited or in MAH
What ever fits, I've used 3300mah before
1 Corinthians 1:18 For the message of the cross is foolishness to those who are perishing, but to us who are being saved it is the power of God.
AtTheCross is offline        Reply With Quote
Old 08-29-2012, 07:48 AM   #3
retroman
I am presently learning plus and minus 's of batteries ha , ha . It came with a 3350mAh. This is basically storage of power right ? If I go up from 3s then I would need a ESC that would handle more Amp ? So I could concieveably get a battery any size I wanted as long as I matched it with the proper ESC ?
Old 08-29-2012, 09:29 AM   #4
AtTheCross
kinda sorta. The stock esc will only take up to 3s on the battery. you can use as many mah as you like as long as the heli will lift it. the more mah the longer the flight but if you get too big of a battrey (larger mah) they weigh more so then the flight time decreases.
you also have to contend with battery dimensions, the battery slot is fairly narrow on the FC so unless you cut away one side (which i did) then you are limited in battery selection.
