Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis > Titan X50E
Titan X50E Thunder Tiger Titan X50E Helicopters
Old 09-18-2012, 10:21 PM   #1
ghenders
Default Main Shaft vertical play
I just posted the below on one of the threads in which this topic came up. However, I believe that this is important enough to post separately to ensure that it is visible to those building/flying the X50e.
You can easily remove the up/down play in the main shaft by adjusting the Main shaft locking collar while it is installed on the main shaft. Here is what I did: 1) Turn the main shaft until the 1 of the 2 set screws on the locking collar is aligned with the small hole in the carbon fiber frame panel and loosen the 1st set screw. 2) Turn the main shaft approximately 45 degrees to align the 2nd set screow with the small hole in the frame panel and loosen it. 3) Push down on the main shaft while pushing up on the main shaft locking collar to ensure that both the spacer at the bottom of the main gear and the locking collar are making contact with both the main shaft ball bearings. 4) Tighten the 1st set screw on the locking collar and test to make sure the play is gone. Turn the main shaft 45 degrees and tighten the 2nd set screw. You are done and the play is gone! This is important because you do want the shaft secured so there is no play during collective pitch changes but also loading the bearings is important for smooth, vibration free operation. Let me know if you have any questions.
ghenders is offline        Reply With Quote
Old 09-19-2012, 07:14 AM   #2
Bob O
Originally Posted by ghenders View Post
SNIP
SNIP
This has been a basic building practice on ANY heli with an adjustable locking collar, no?
Warp 360 Spartan Vortex VX1
Bob O is online now        Reply With Quote
Old 09-19-2012, 11:39 AM   #3
ghenders
Yes indeed! However, the reason I posted this is because there was a thread started in this X50e sub-forum where several folks were compaining of this vertical play and the replies were "no big deal" and "mine does the same thing" without anyone actually posting how to rectify. So, I decided to share how to resolve. However "elementary" it maybe there are folks who might not be aware and could benefit from the instructions.
Old 10-02-2012, 03:08 AM   #4
R3L72
Thumbs up Agreed...
I definitely agree with the re-posting of this information for the X50e. It helps up and coming kit builders such as myself with the Basic's.
I for one will not ask/search, for what I know not to ask/search for...
CY NextD Rave 3D, MSH Mini Prôtos (6S) Stretch, Prôtos 500 Stretched
Blade 450X, 300X, 130X, mCPX, Nano, DX6i, DX8
Align Trex 450 V2 Pro DFC, & too many others to list...
...living the Hobby 4+ minutes at a time
R3L72 is offline        Reply With Quote
