| Scorpion ESC and Motor Support Scorpion Power Systems ESC and Motor Factory Support Forum |
#21 | |
Thanks Greig |
#22 |
I have the positive wire coming out of the third port.
Gaui X5 FES, Scorpion 910kv, Gaui GS-501, Gaui GS-502, BeastX, R6208SB Gaui X7 FES, Scorpion HKIII-4035-500, Torq BL9180, Savox SB272-MG, Mini vBar, R7008SB 18MZ |
#23 |
#24 |
I can confirm that using the same method as chadew, I can charge the backup guard using my PL6 and EP buddy parallel board.
#25 |
Hi friends! I just acquire the famous scorpion backup guard and I had the same problem as many of you: how to load solely by this small sheet battery balancer, the solution is simple for those who kept their small helis charger FP style T2M Spark 435 and it works great! Arise therefore these small chargers and your problems are solved
Cheers ! Feeprog |
#26 |
Charged mine using.a PL8 and the batteri just plugged into the balance board, no powercables connected
Nano CPX, 130x, Trex250, 450Pro, 550 & 600EFL Pro. SAB Goblin 500 & 700 - Lynx Team Pilot - |
#27 |
Just picked up four of these. Will run every heli with one now. Seems like very cheap insurance.
Goblin 700, Goblin 500, Synergy E5-600, Fusion50, Rush7 HeliDirect, Team iKon, GrandRC |
#28 |
The manual says rated ten amps,but I been told by western robotics a spade connecter is only rated to 5 amps ..? Can this be used as a good buffer pack than ?
#29 |
im guessing since i already run a 2s lipo direct at 8.4v it would be pointless for me to get.
Dx8 mCPX bl v1 hp05s130X GauiX2FESds11,ds95i beastx Gaui X5FES,AR7200BX,Xera4020Torq9088,9188 |
#30 |
Less usefull unless your running a bec, but still a backup if you forget to charge or somethings comes unplugged
#31 |
don't like how / where they placed the indicator LED , not so easy to see the light
I'm charging mine using an old Esky charger
Trex 500 : Atom FBL head AR7200BX | Atom 6HV : vbar 5,3 pro | Goblin 700 : vbar 5,3 pro | Goblin 500 : vbar 5,3 pro |
#32 |
#33 |
I always store my lipos 60%
Logo 600 - PD-Scorpion 4225 470kv+vbar gov/YGE120hv/Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+ Hobbymaniac Teampilot |
#34 |
Was having brown out issues when running a WR BEC at 8.4V with Align 700H HV servos (Savox). With the backup guard installed the problems are gone.
Installing 3 more backup guards now. Only wish: -Auto on feature. Not loving another step. Manual off of course. -Should use clear heatshrink so we can see the LED.
#35 |
I would just like to say "hats off" to Scorp. for effeciently rounding out a turn key electronics setup!
![]() That is to say... one stop shopping for motor, esc, and emergency backup. WAY TO GO! Wiz
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#36 |
Well, I just picked up a scorpion guard myself. I built a charge lead as some of you as well and got to wondering about this...
I guess I'm trying to decrease my workload as much as possible I'm wondering this because, if it is fully charged, and doesn't ever get used(being a backup!) then it's not really healthy for the little 2s! But even at 60% there should be plenty of live left for a successful recovery in case of a bec failure! Any Opinions? |
#37 | |
As I understand its function, that setup should work fine. During normal charge it will send equal current through both balance leads. While balancing, it sends no current through the main lead, so each cell will get +ve or -ve current thru its balance lead accordingly. EDIT: I just looked at that setup again. Unless I'm mistaken, the respective cells on each balance port are wired in parallel, but within a given port, the cells are not connected except by sharing a common ground. However, if you say the iCharger shows the correct voltage (8.4V fully charged) on the main lead then I must be missing something. |
#38 | |
So between charging and discharging it every day or just keeping it at a storage charge, it would make sense to me to go with the latter. However, you'll still need to charge it back up to storage level every time it engages. The bad part about this component seems to be that the battery is not serviceable. Would seem feasible to provide a plug-and-play version where you provide your own LiPo (or LiFe?) pack. |
#39 | |
#40 | |
just used mine today for the first time......balanced it at .10amps took an hour.
using this on Gaui X5 with the NEW YGE 90LV internal BEC 6amps 12 peak. flew four times. removed. voltage dropped from 8.4 to 8.3.....which is prolly just where it rested at after charging. im sold. ![]() getting one more of these for my compass 7HV which has a WR Herc Super BEC. no point in getting one for my Goblin it runs direct 2s. but then again it would be nice if something were to come unplugged. shit i better get 2 more
"How high does it go?" Love that question..... To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
