| MA Glow Miniature Aircraft Glow Helicopter Support Forum |
http://www.heliproz.com/MA128-114-13...nfo/MA128-114/
http://www.heliproz.com/MA128-112-Cl...nfo/MA128-112/ http://www.heliproz.com/MA128-110-Cl...nfo/MA128-110/ I have the whole unit, the one that is 68 bucks, and the pinion does not screw out. Are the first two links new parts? Are they a drop in replacement?
Jake Team AleeS RC, Team A Main Hobbies To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. AleeS RC Rush 700, MA Fury 55, Trex 450fbl pro, Blade 130X |
The pinion WILL screw out ......
Peter To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Furion 6 FBL ; E,N and G Whiplash FBL ; 3 Spectra G FBL ;3 Stratus FBL ;MA Extreme+E Razor+N Razor +Fury 55 FBL;xcell 60+xcell 70: Aeolus KME 60 , 2 Velocity 50's FBL; few 500's.. All BeastX ; guided by XPS . |
#3 |
Yep it does unscrew, it may be tight but it will come out.
Rudy - Bend OR/Houston TX We had a great country once. You know what made it great? “I can.” Then the weak came along, “the I cant’s” and destroyed it. |
#4 |
okay thanks. I was looking in my manual for something else and noticed that the clutch bell is two parts, pre-assembled at the factory. cool
