Old 10-21-2012, 04:56 PM   #41
dpelletier
Originally Posted by soko View Post
im still not getting how you english guys differentiate between relative angle/level and absolute/spirit angle/level
What makes you think we differentiate?!?
Dany
Synergy E5 in the works
Furion 6 Flybarless, Skookum 720
Beam E4(v1) FBL, Skookum 540
dpelletier is offline        Reply With Quote
Old 10-22-2012, 01:56 AM   #42
soko
I don't know what english word to use when I like to talk about an angle between two surfaces...
realtive angle, relative level, ???
And what word you use when talking about a surface that should be aligned in an angle relative to the earth level. In German we say the object is "in water" - but that doesn't apply to english. I'm currently using "absolute level" when talking about the level that is given by the instrument you call "spirit level" or "bubble level". the one carpenters use when they ar building a house.
Maybe someone can clarify to me the right terms to use
Soko
ONE TOOL for ALL SIZES and ALL BRANDS
"Unique features" | "Awesome setup tool" | "its simply awesome"
www.soko-heli-tools.com
soko is offline        Reply With Quote
Old 10-22-2012, 03:07 PM   #43
georgi UK
if you are describing the angle difference between two surfaces, where one is ie, 5 deg different to the other, this is called the "included angle" this is the angle difference between the two, and not relative to anything outside of itself.
for this one we talk in terms of the horizon, and use "horizontal" as the adjective, vertical is 90 deg to this. "perpendicular" can be used to convey a heli mast that is 90 deg to the horizontal looking from the side, and also from the front.
Soko
georgi UK
georgi UK is offline        Reply With Quote
Old 10-22-2012, 03:23 PM   #44
soko
georgi
In our instructions we are talking about absoute/spirit level. Will the guys get the drift or should I change it to horizontal/vertical?
Soko
Old 10-22-2012, 04:02 PM   #45
georgi UK
georgi
Soko
=] horizontal / vertical can only mean one thing as an absolute reference. these can then be expanded to "looking from" the side, the front, the back etc.
absolute spirit level conveys an instrument that, in itself can be inaccurate. so yes, the correct terms are vertical, horizontal.
we all understand this meaning!
georgi UK
Old 10-24-2012, 10:40 PM   #46
neavissa
Soko
LOL, I have to go through this all the time! I am Greek, born and raised in Germany! So I speak three languages... I am always looking for the right words! Never heard "in wasser" thought?!
G
p.s. I got totally confused with all that level talk. My new "level" bottom plate for my frame is gonna be here on Friday. As soon I installed it and mounted the SK, I will post a picture and you guys tell me if I am right on or not!
neavissa is offline        Reply With Quote
Old 01-17-2013, 09:02 PM   #47
Luvmyhelis
Soko, I was just re reading this entire thread again. I admit,the concept prompted me to buy a one time deal on a DX8 last summer. It basically sat until today. Now I am finally setting it up per your instructions. Good stuff!
But just to be clear. What did you mean about reversing throttle and pitch curves?
Luvmyhelis is offline        Reply With Quote
Old 01-17-2013, 09:08 PM   #48
soko
Hi Randy,
With reversing I mean reversing the order they are on the flight-mode-switch.
I use idle-up2 to start and take off. idle-up1 for normal flight and "normal" for SL (bail-out).
Otherwise you have to get your hand under the flight-mode-switch and switch to idle-up2 to activate SL in an emerceny. Way to slow and to dangerous to miss.
Do you know what I mean?
Soko
Old 01-17-2013, 10:38 PM   #49
Luvmyhelis
Hi Randy,
Soko
Yes! Thanks.
I saw the explanation about that earlier but didn't separate the two. Awesome! I should have this little beast up and flying tomorrow.
Old 01-18-2013, 08:26 AM   #50
ICNU
Originally Posted by Luvmyhelis View Post
Yes! Thanks.
Hi Randy. I used Sokos flight mode method for bank switching listed here with my DX8, and it works quite nicely. The one thing I did notice, at least on my heli, is that trimming the SL mode doesn't always work well from one flight day to the other.
I could get it trimmed perfectly one day, but would need to start over again when flying at a later date. I'm assuming this could be from differences in temp, etc. Its really no big deal.....I would just spend about 30 sec trimming the heli for perfect SL on my first flight, and then I was usually good for the rest of my flights.
It would be interesting to hear your experiences with this from one day to the next.
Goblin 630 /SK720 with GPS
T Rex 500 EFL Pro/DFC/SK720 with GPS
Brushless and blinged MCPX
ICNU is offline        Reply With Quote
Old 01-18-2013, 01:18 PM   #51
soko
hi icnu.
The drift differences between days is exactly why I came up with this trim-idea!
on each fly day i reset the SL trims at the beginning to find "the values of the day".
other systems (msh brain, ikon) has such a trim in the software which is kinda useless due to the fact described above.
Soko
Old 01-18-2013, 07:26 PM   #52
ICNU
hi icnu.
Soko
Thanks Soko! I have since changed mine over to a momentary switch for SL, and a bit of pitch mixed in to make the heli climb. This climb kills any drift I would typically notice, so I don't even see it anymore
Old 01-18-2013, 07:55 PM   #53
soko
Good to hear!
Maybe you can sum up how you add the pitch. I read about it a couple of weeks ago but forgot how it works. Something with the mixing in the Tx isn't it?
I reckon all the guys reading this will appreciate the input. For me I'm OK with controlling the pitch myself
Soko
Old 01-18-2013, 08:01 PM   #54
ICNU
Good to hear!
Soko
Yes, it's a simple Aux2 to pitch mix. I did a thread about it here: Its a long read, but its hard to describe in one paragraph.
http://www.helifreak.com/showthread....489086xcsddfvf
