Old 09-10-2012, 02:46 AM   #21
chopstick
I just started with a SK540 on my Compass Atom550.
So here's my setupfile: posted in : http://helifreak.com/showthread.php?t=445041&page=4
I disovered I couldn't upload the same file on 2 posts, so linked it.
My setup is as follows:
Atom 550, stock blades, KBDD tailblades 84.5 mm
swashservo's align DS510
Tailservo : align DS650
ESC kontronik Jive 60 amp with heatsink
My endpoints for cyclic in the TX are 30/32 (bank 1 / bank 2).
I locked the tailgain, and switch the tailbank with thesame switch as the cyclic banks.
Only difference in the tailbanks is the controlrate.
If you have improvements, be my guest.
I'm still in the adjusting fase. Finding the best settings for my flyingstyle (mild 3D).
LOGO 400SE : Skookum SK540, Scorpion 3226 1230kV
SJM180 : Tarot ZYX
Rigidheli.com: The place where Dutch Helipilots meet
chopstick is offline        Reply With Quote
Old 09-16-2012, 07:44 AM   #22
pugdavey
Anyone got a file for a 450pro?
Sent from my LT26i using Tapatalk 2
7HV,EL Brute, HW120 hv, bls 451,251, SK540
Warp, mks92a, ds525,hw40pl, sk540
Lynx team pilot
pugdavey is online now        Reply With Quote
Old 11-19-2012, 02:10 PM   #23
Spork01
Yes I would like to know what other 450 pro fliers is using.
I'll post mine when I get a chance tonight or tomorrow
Trex 450 Pro V2 FB spartan quark
trex 250 beastx
Fusion 50 beastX
Spork01 is offline        Reply With Quote
Old 11-20-2012, 11:11 AM   #24
RyanB
I'm still working on getting my 450 Pro dialed in on the 540. Once I get it worked out I'll post up my file and specs. Like Spork I'm curious to find out what others are running.
RyanB is offline        Reply With Quote
Old 02-04-2013, 06:08 PM   #25
JBlade@HF
Would be great to get the set-up from someone who has fully tuned their 450Pro with the SK540. I'm gradually getting mine where I like it, but it still tends to drift with the wind, and I'm not sure what I should be adjusting to make it more stable.
JBlade@HF is offline        Reply With Quote
Old 02-08-2013, 06:12 PM   #26
CHIEF-X
check this thread out in the sticky section
http://www.helifreak.com/showthread....26#post4710626
FUSION 50 12S SK540 TORQ WITH QUANTUM/HOBBYWING POWER SYSTEMALIGN TREX 450 PRO V2 BEASTX 6S MKS SERVO'S GAUI X5 FES BEASTX DX8
WINDANCER
COMANCHE TRIBAL MEMBER 4TH GENERATION
CHIEF-X is offline        Reply With Quote
Old Yesterday, 01:39 PM   #27
NavaraHeli
Post Skookum 720 help please?
HI all
I am new here especially with the Skookum so please help?
I have a Skookum 720 setup on my heli.
I have done all the wizard setups as were told. Now I have the issue of when I test and tilt the nose down, the Skookum is not countering the swash and instead gives extra pitch. this goes for Aileron as well as Elevator?
Is there any values I need to setup to negative instead of positive or what do I need to do or is this normal. As far as I know and have learned that it is suppose to counter?
And what would be the ideal pitch settings neg , mid and pos?
Any help will be much appreciated please?
Heli:
Scale BO 105
OS 90 SZ
JR 8301 digitals
ALign ds 655 tail
Vario 4 blade head and Vario scale blades
Robbe Shluzer Millenium 90 size frame
Regards
NavaraHeli is online now        Reply With Quote
Old Today, 04:06 AM   #28
georgi UK
=] have you set the handset to 1 servo 90 deg swash type? all mixing is done in the SK....
georgi UK
georgi UK is offline        Reply With Quote
Old Today, 12:54 PM   #29
NavaraHeli
Default Skookum setup
HI
yes, 1 servo 90 degrees setup.
I cant upload the setup file cause it's a .sk7 file extension. Any way I can change it?
thx so far
Old Today, 01:29 PM   #30
georgi UK
=] if this is a dx6i change the swash mix to a negative value, mail me the setup file = gmcallister@ocvc.ac.uk
georgi UK
Old Today, 02:31 PM   #31
NavaraHeli
Post
Sorry forgot. I have the Aurora 9 with Optic 9 RX
