Old 11-28-2012, 11:23 PM   #1
cafediablo_30
Default total newb to sbus and vbar
I've just started using my futaba 8fg on sim only,..now to hook up th real deal...I have no clue how to power up both the mini vbar and rx,..and if I keep fiddling around I'm afraid I'll burn somthing up,..I have a r6108sb and as far as I can tell if powers up on the 8th channel,..at least it seems to power up,...and th vbar can be powered through the rxb,..do I use bec to power the rx and the esc to power th vbar,..hope I can get the answers I need before I mess this up,..thanx.
cafediablo_30 is offline        Reply With Quote
Old 11-30-2012, 10:05 AM   #2
chadew
The power will pass through the sbus cable between the mini vbar and the rx. You only need one power source in either device and it will power both. The rx will power up on any servo port and the vbar will power up on ports except rxc I think.
Things may change if you are running a HV setup. In that case you would have two power leads out of the ESC or BEC. It is then recomended that one power lead goes to the rx and the other to the vbar.
Gaui X5 FES, Scorpion 910kv, Gaui GS-501, Gaui GS-502, BeastX, R6208SB
Gaui X7 FES, Scorpion HKIII-4035-500, Torq BL9180, Savox SB272-MG, Mini vBar, R7008SB
18MZ
chadew is online now        Reply With Quote
