Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > Cypher 3D
Cypher 3D EF Cypher 3D
Old 07-31-2012, 03:28 AM   #2121
lawrencelkl
Originally Posted by Cryptovariable View Post
When using the stock ESC, I had 0,40,80,90,100 in normal and 100,90,80,90,100 in idle up.
The simulator is the most valuable tool you can have at this point. Fly a lot on there and don't try anything in real life that you can't do on the simulator proficiently.
Hi J,
Thanks for the info. I will try to learn stall turn more before attempting loop. one question, can we actually use and simulate idel up function in simulator? i have Phoenix rc simulator version 2.5 i think. I.e. if we set up idel up tx, when plugged in , can we use it directly or need further configuration ?
cheers.
Lawrence
lawrencelkl is offline        Reply With Quote
Old 08-01-2012, 09:47 AM   #2122
Cryptovariable
Lawrence,
When you run Phoenix 2.5 on a computer connected to the Internet, it should automatically update you to Phoenix 4.0. You might want to do that if possible.
Also, you can use idle up in Phoenix. Make sure the collective pitch is set to channel 6 in Phoenix (leave the throttle on 1) so when you go into idle up on your radio, Phoenix will see the independent curves.
Hope that helps,
J
Cryptovariable is offline        Reply With Quote
Old 08-07-2012, 09:38 AM   #2123
lawrencelkl
Hi J,
Thanks for the information. I will try to do that.
Regards,
Lawrence
Old 08-13-2012, 01:53 AM   #2124
Cryptovariable
Hey guys...
What am I doing wrong? Which way is the tail supposed to bend? Left or right? I can't seem to get it working right!
J
Old 08-13-2012, 02:58 AM   #2125
rcjames
Hey guys...
J
You do suppose to be funny right? LOL Tail housing shifted haha. Nice blades!
Hi my name is Jim and I am a Heliholic. Darn Heli-Crack Addiction!! lol
The heli virus has infected me and i hope that there is NO CURE!
rcjames is offline        Reply With Quote
Old 08-14-2012, 07:52 AM   #2126
lawrencelkl
Hi All,
I have made a big mistake...too keen to fly my cypher once I installed the eletronics etc, the screws holding the ball link on the swashplate came loose and there gone the woodies blades, lesson learned, locktite all the screws, then put on cheap carbon fiber £ 5 blades, it is hovering ok now.
it handles mild breeze quie well, as others said, i find it nose heavy with 2200 and 1800 mAh lipo packs, do i need to worry too much or it is find?
Cheers and enjoy flying.
btw, anyone ever put readily available scale body onto cyphers? if so, mind to share some links/ photos/ cheers
Regards,
Lawrence
Old 08-18-2012, 05:37 AM   #2127
fourbie
OMG - this is a long thread. I confess I haven't read it all!!
I have just put together my Cypher.
I didn't need to do as the booklet says to install the elevator servo which is to remove the main gear but I did do it cos I didn't know better!!
I am using cheap stuff on it cos it was a present so I have a Hobbyking gyro. This is the second I have on a heli. I can't get the tail to stop big wags. Are these gyros just rubbish? Do you Cypher guys have any suggestions?
Have a great day - John
"Do it to them before they do it to you" {Hill Street Blues}
When the blue light is flashing I am kidding. E&OE.
fourbie is offline        Reply With Quote
Old 08-18-2012, 08:32 PM   #2128
kevinbattista
try turning your gain down or up on the gyro.
it's kinda hard to say what causes a problem if you cant see the problem.
try posting a vid ?
as far as the Hobby king gyro ...
cheap electronics make a terrible flyin heli .. bottom line.
this is what i had in my Cypher (now in my EXI)
flew great
cyclics= DS 410
esc= Align E35G
bec= Castle creations 10amp
motor= Align 430xl
RX = FUTABA R617FS
Gyro = GY401
Tail Servo = s9257
it's not a competition, it's a hobby
EXI 450 + FUTABA t7c Tx =
Phoenix Sim "it's free to crash on a sim"
kevinbattista is online now        Reply With Quote
Old 08-19-2012, 02:37 AM   #2129
fourbie
Yes I do agree. I'd like 401s in all my kit.
The first HK gyro was one in a used Mini Titan I just bought. The seller said the Titan flew great but it turns out he stripped out his Spartan and replaced it with an HK for the sale and it is a bit temperamental but I didn't get to fly the Titan before I bought the HK for my Cypher. Looks like I need two gyros now!
I tried fiddling with the gain till I am blue in the face. I have an old rate gyro which I know works that I will try next.
Old 08-19-2012, 04:08 PM   #2130
fourbie
Tried it with a CSM rate gyro and it flies as steady as a rock.
Old 08-20-2012, 12:04 AM   #2131
kevinbattista
Good to hear
Old 11-30-2012, 08:33 PM   #2132
irjamesm
Hey Guys, long time no talk.
Just flew my cypher today after I dont know how long.. Did pretty good, didnt crash.
Then it started raining and had to stop after only 1 pack.
Any how hope you are all still around and doing good.
Still have an issue on the heli that the tail wants to keep drifting clockwise,add trim and it makes do difference.
James
EF Cypher 450
EXI 500
irjamesm is offline        Reply With Quote
Old 11-30-2012, 11:52 PM   #2133
Iceberg86300
I drove mine into the ground awhile back, wasn't worth rebuilding and hobby people stopped selling the m. Shame too, it was a great bird for the price.
Regards,
Steve
Sent from Tapatalk using my Inspire 4g through ATT (meaning it's a wonder you can see this!)
Align T-Rex 450 pro v2 g3x FBL (in progress)
Stock except for Hyperion 35A ESC in gov mode
Futaba 7c transmitter
Hyperion 720i NET charger & RDU data logger
Iceberg86300 is online now        Reply With Quote
Old 12-01-2012, 11:28 AM   #2134
dialarotor
Smile Not to worry
Ron Lund at Heliproz South still supports the Cypher 400 3D and has 17 kits in stock and parts.
Makes me feel good about building mine. Neat little heli.
http://www.ronlund.com/rcheli-prod/EFCYPHER400.html
dialarotor is offline        Reply With Quote
Old 01-07-2013, 10:04 AM   #2135
lawrencelkl
Hi All,
Happy New Year everyone, just a quick note to tell that at leat I am still flying my Cypher in 2013.
Only repair was the landing gear 'rod' that was broken from a harsh landing in very cold weather. I guess the cold weather made the plastic a bit more birttle?
pulled out the broken and replaced with a spare one i got from 450 sized heli. and she is back to fly again.
in my opinion, she is still too quick and too responsive for my skills but I am learning it!!
cheers and enjoy flying all!
Old 03-20-2013, 02:25 PM   #2136
Cryptovariable
Hi guys,
Just thought I'd share that I helped set the [3/9/13 Las Vegas Fun Fly] Guinness Book of World Records record for the most R/C helicopters (60) in the air at one time with the Cypher 3D! I can guarantee that I was the ONLY person there flying a Cypher! Bet you'd never think that a Cypher would be flying in the same 'event' that had Kyle Dahl and Danny Szabo flying in it!
I assume I'm probably one of the last people in the US flying the Cypher on a regular basis. What blows me away is that you can get ALL the replacement parts EXCEPT the mainshaft these days. I don't get how Hobby People thinks they will ever sell any of the other Cypher parts if you can't get the number one part that usually bends in a crash. I guess they don't really care at this point.
Anyone else out there flying their Cypher still? Anyone have any new in the package mainshafts laying around? I can make my own, but I wouldn't mind having some of the originals.
Take care,
J
ID:	405131   Click image for larger version
ID:	405132   Click image for larger version
Old 03-20-2013, 02:42 PM   #2137
fourbie
Take care,
J
Excellent information, well done.
If I had a mainshaft I'd lock it in my safe after what you've just told us.
Old 03-20-2013, 03:06 PM   #2138
lannny
what size is the cypher? 4 - 600 size?
lannny is offline        Reply With Quote
Old 03-21-2013, 08:13 PM   #2139
Cryptovariable
It was a 400 class.
Old 04-06-2013, 09:12 PM   #2140
Iceberg86300
Default Re: Cypher 3D - Love this Heli!
Anyone need parts?
I have BNIP 2 fly bars, 2 main shafts, 2 spindles, and one loose spindle (not sure if its straight) and a pair of blade grips and ball links but no blade bolts.
Regards,
Steve
Tags
airtronics, cypher, make that the esc
