| Align 3G FBL System Align 3G FBL Flybarless System Software and Hardware Support |
I've just replaced my aging 3G for the 3GX but struggling to fine info on setting throttle & gov in tx, done the gov sync with with 3GX so just need an idea what to set the throttle norm mode & idle 1/2 & the atv for gov
DSX9, Phoenix Sims, Blade Nano, mCP X, 130x Trex 250pro DCF, Mini Titan 325se 3G. Trex 450v2pro 3GX, Trex 500EFL 3GX. Trex 600NSP 3G FBL, Trex 700n 3GX. |
forgot to mention this is for my 600n but also got 700n to do.
#3 |
Use mixing, here's some examples. First is 3GX no gov in normal and two speeds using the gear switch.
![]() No gov setup in normal ![]() Switched to IU ![]() Here's one for my vbar, two mixes, the second adds to the first to get two speeds with the FMs Mix1 FM 1and2 and mix2 FM2 ![]() ![]()
Align 450Pro 3GX, Align 500 3G Align 550 3g, Velocity 50 Vbar |
#4 |
My TX is DSX9 so only need to use atv for 'gear' + is gov & - is rate mode so i assume i keep throttles curve v's in iu's as if mechanical setup then in gov mod set to around 60ish %.?.
#5 |
Set usable v curves just incase the gov fails and you good to go.
Linked up it will show you the head speed for your settings after inputting your gear ratio.
