Go Back   HeliFreak > R/C Helicopter Support > Century
Century Century Helicopters Support
Old 11-17-2012, 06:46 PM   #1
FR4-Pilot
Default Swift NX Motor & Battery Connector Question (& Misc)
Does anybody know what size these are:
Battery/ESC Connector
Part# CNE5513BAESC
and what size these are:
Motor/ESC Connector
Part# CNE5513MOESC
(4mm by chance?)
I finally received my YEP 100A ESC for my 2nd Swift NX build. It will use the Century 650A 800kV motor on 6S. I need to get battery & motor connectors. Trying to decide if I should use Deans or move up to XT90s or EC5s on the battery. I'm thinking 4mm will be okay on the motor leads, but I don't know what the amp draw of the 800kV motor is - I'm guessing 80-100A ? My 800kV currently has 4mm bullets on it. My only real concern is current/amp ratings - I don't really have a favorite connector style (sorry).
Here's what I've read:
Deans - 40A (have these on my 1st NX with 1100kV & 6S - probably should change them out)
EC3 - 60A (3.5 mm)
XT60 - 60A (3.5 mm)
Century ? - 80A (4mm) ?
XT90 - 90A (4.5 mm)
EC5 - 120A (5mm)
What are you e-guys running?
Thanks,
-John
DX6i (x2); Eachine FatBee (Hacked-Bee) FB90; Blade Inductrix FPV, 180CFX (x2), 400; Thunder Tiger Mini-Titan E325 V1, SE & TT; Century Swift 16 & NX; Hirobo Quark SRB (x3); Flyzone Sensei; E-Flite Apprentice 15e; Phoenix; RF7.5;
Blog: http://tamingtheblade180cfx.blogspot.com
FR4-Pilot is online now        Reply With Quote
Old 11-17-2012, 10:54 PM   #2
Dennis P
These measure 3mm inside .Look like a EC3 but a little longer barrel.
CNE5513BAESC
I do not have the others in stock.
I have ran the deans in 6s applications and they have been fine.If running with a hot motor and high headspeed and constant heavy cyclic I would say run a EC5 and there would be no issues.Feel the plug after flights and if it is warm at all you know it is not up to snuff.
Team Renegade R/C Heli Flyers
Dennis P is online now        Reply With Quote
Old 11-17-2012, 11:13 PM   #3
FR4-Pilot
Thanks for measuring those Century connectors - I assumed they were 4mm.
The Deans on my NX with the 1100kV don't ever seem hot, but that motor doesn't pull as much current as the 800kV (I believe). Good to know about the Deans though.
Old 11-18-2012, 11:58 AM   #4
MotorRotor
The amount of current that a motor pulls is not much of a KV rating issue, as it is of a head speed and battery pack voltage issue, related to the watts required to fly the heli at the rotor speed desired.
For example: If it takes an average 800 watts to fly the heli in a given manner at a 2000 rotor speed, using a 22.2V 6S pack, then the average current will be 800/22.2 = 36 amps.
The difference to do so between a properly geared 1100KV motor and a properly geared 800KV motor will simply be the difference in the number of teeth on the pinion gear, and maybe a slight difference in ESC settings. But both will be required to deliver 800 watts and use an average current of 36 amps.
Related to the battery pack, if you wanted to do the same using a 5S (18.5V) pack, you would again need a different pinion and would require higher current. The math is simple: 800/18.5 = 43.25 amps.
Phil
MotorRotor is offline        Reply With Quote
Old 11-19-2012, 10:18 AM   #5
karl k
For an idea of current draw to expect, I saw 44 amp peaks when using FunKey 550mm composite blades at 2000 ish headspeed and 11 degrees of pitch in a full collective punch out. This was read using telemetry.
This might be a good reference for you as well. It's in German, so your browser will have to translate for you. Shows most of the popular connectors except for power poles.
http://www.elektromodellflug.de/oldp...romstecker.htm
For a visual representation of how Deans and APP (Anderson Power Poles) deal with high current, there is this video showing how and when they fail.
karl k is offline        Reply With Quote
Old 11-23-2012, 09:54 PM   #6
FR4-Pilot
I ended up going with Deans and 4mm bullets on the ESC. I'm not a smack 3D flyer so I don't think I'll be melting any equipment
ALL of the electronics are finally here and appear to be in working order. That YEP sure has lots of programming options - some tweaking to be done there during the initial flights for sure.
Does anyone have pointers/experiences regarding the YEP setup they might be willing to share?
-John
Old 11-24-2012, 11:32 PM   #7
Dennis P
YEP I cannot help you with this one Sorry could not help myself
Old 11-26-2012, 09:14 PM   #8
FR4-Pilot
No problem Dennis
My Turkey-Day 550mm rotor and 85mm CF tail blades arrived today I guess I know what colors I'll be adding to the canopy ...
-John
ID:	369133   Click image for larger version
ID:	369134   Click image for larger version
Old 11-27-2012, 06:11 AM   #9
Greybird
Where are the blades from? Can you post another pic with the canopy and blades in 1 shot? That color combo looks great!
Greybird is offline        Reply With Quote
Old 11-27-2012, 08:58 PM   #10
FR4-Pilot
Those are EcoPower CF Blades from Amain Hobbies:
http://www.amainhobbies.com/product_...r-Blades-550mm
and
http://www.amainhobbies.com/product_...or-Blades-85mm
(they were 1/2 price last Thursday and Friday)
I'll post a 'real' pic of the heli after I actually decorate the canopy with colored tape. That pic is actually a photo I edited in MSPaint - I wanted to get an idea of how it would look before actually cutting tape (apologies)
-John
Old 11-27-2012, 10:31 PM   #11
FR4-Pilot
Okay - you got me thinking - why not doctor-up another photo:
or
ID:	369417   Click image for larger version
Old 11-29-2012, 06:16 PM   #12
Greybird
That is a nice look.
Old 11-29-2012, 07:48 PM   #13
FR4-Pilot
Thanks Greybird - hopefully I can actually get it to look like that.
BTW - what's your Grey's name? I have a couple of Grey's too ...
-John
Old 12-01-2012, 09:26 PM   #14
ngin
What are you planning to use for the colors - Monocote Trim Sheet or paint?
ngin is offline        Reply With Quote
Old 12-01-2012, 09:29 PM   #15
FR4-Pilot
That's a great idea Ngin! I'd like to give those Monokote trim sheets a try - I guess it depends if I can minimize the wrinkles .... loads of colors for sure.
Do you know if that material is soft/workable or is it stiff like the original NX decals ?
Old 12-08-2012, 08:19 PM   #16
ngin
It is much more flexible then the decals.
