Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Old 12-16-2012, 11:04 PM   #1
vteknical
Default Maiden Flight and Build shots with Full Size Vbar
I finally had a maiden flight today! Only one tank as Holiday family activities took precedent. I need to break engine in, tweak Vbar, hot glue the Vbar connectors, tweak Governor or even switch over to 2 channel mode.
Upgraded Items:
Metal Align fan.
Lynx m3x6 screws
Pitch slider maybe align maybe Gaui waiting to see if they replace non-damage pieces.
ID:	374761   Click image for larger version
ID:	374762   Click image for larger version
ID:	374763   Click image for larger version
ID:	374764   Click image for larger version
ID:	374766   Click image for larger version
The bitterness of poor quality, lingers long after the cheap price is forgotten.
Buy the best and only cry once!
vteknical is offline        Reply With Quote
Old 12-17-2012, 01:04 AM   #2
tauscnc
That is great news! Can you tell me more about your radio setup;
- what does the cell phone do
- what mount is it
- How does it work
Looks great!!
tauseef
tauscnc is offline        Reply With Quote
Old 12-17-2012, 08:19 AM   #3
vteknical
Thanks you.
The cell phone setup uses a Bluetooth app to control all Vbar settings.
It is mounted on a GoPro camera bracket. On the phone I also have the Gopro wireless App, which allows wireless video playback from a Gopro mounted on a Hexacopter.
Old 12-17-2012, 08:39 AM   #4
caralmar
VERY clean wiring job! Me likey!
Do you have any problems closing the canopy with the vbar mounted on the side like that? That may be an option for me, although I would hate to re-wire this bird!
Where did you end up on the vbar for your throttle end point for motor on/off? On mine, I ended up at 80% for Motor full throttle and -115 for motor off. I'm not getting good performance out of my setup and it could be that the vbar governor doesn't have good enough resolution on the throttle channel...but I'm not sure. It bogs doing tic tocs and sometimes when I do a fast pass and then flick the cyclic up fast to go inverted stop, you can hear the engine almost flaming out.
AmainHobbies/ProTek Field Rep
Rush 700 * Trex 700N x 2 * Trex 600Pro * Gaui NX4 - V-Bar on all
AMA #934662
caralmar is offline        Reply With Quote
Old 12-17-2012, 09:34 AM   #5
Goodlett
I see you got a switch and a sg mounted in the same vicinity. Are you going to cut a hole in the canopy?
Goodlett is offline        Reply With Quote
Old 12-17-2012, 10:02 AM   #6
tauscnc
I see the XT-60 connector. Nice. I ditched the Deans for those and have never looked back.
tauseef
Old 12-17-2012, 06:01 PM   #7
joallen001
Looks great! Love the wiring. Is that a particular fan everyone is using as a replacement.
joallen001 is offline        Reply With Quote
Old 12-17-2012, 10:19 PM   #8
vteknical
Canopy closes extremely easy with this setup with no restrictions at all. I had to tack the box with double sided a couple times up and down ever so slightly to get the fit just right. My throttle was -115 in off and approx 75 for full. Still not sure if I like the Gov since this was just a test run hovering. @Joallen001 I used the metal Trex 600N fan for 20.00 it also comes with a set of magnets. Do it and don't look back. The stock fan is crap! I really like the size of this nitro bird, it has some serious power almost cheek clenching.
Old 12-17-2012, 10:23 PM   #9
vteknical
Yes I bored a hole out with a Dremel. This really added undue stress to my type A psyche but the benefit out weighs the con.
Old 12-27-2012, 05:54 PM   #10
daisydog
vteknical
The wiring looks great. It's a clean looking job.
What tape did you use for the V-Bar sensor? I see the metal plate but am wonder which tape for the sensor to the plate, then the metal plate to the heli.
Thank you
Joe
SAB Canada, RotorQuest
daisydog is offline        Reply With Quote
Old 12-27-2012, 09:22 PM   #11
vteknical
Thank you. The metal plate comes with tape already mounted. The layer on the bottom(plate to Helicopter)is the vibration pad and the tape mounted to the sensor and plate is like 3M mounting tape.
Old 12-28-2012, 07:17 AM   #12
daisydog
vteknical
Thanks for the info on which tape.
Happy flying.
