Old 12-14-2012, 02:44 PM   #1
FPVflyer
Default NAZA-H problem in manual mode
Hi peoples,
I finished to setup my NAZA-H today, all the step into the driver was good. The only strange thing is that when I turn on the system the swashplate in manual mode is in a wrong position, and the corrections to movements are very slow. Controls are right.
If I switch to ATTI mode, swashplate go on neutral position and the answer to movements begin to be very fast.
To avoid a big crash on maiden flight, can someone help me understand this problem?
Here a small vid about the problem.
https://vimeo.com/55634114
pass: freak
FPVflyer is offline        Reply With Quote
Old 12-15-2012, 09:23 AM   #2
flim63
First off, make sure the setup procedure was done with all Tx settings at default (no expo, trims or curves set). I'll look at my setup this afternoon and compare to your video but swash should be level in manual mode I believe.
flim63 is offline        Reply With Quote
Old 12-18-2012, 10:56 PM   #3
Tahoe Ed
Here is a test that I did in manual mode:
In ATTI the movement slowed significantly and became more erratic. Hope this helps.
AMA #844172 DJI S800 WKM Z15 Nex5N iOSD Data Link Waypoint DJI F450 Naza + GPS with 5.8gHz vTx
DJI Phantom with GoPro3, DJI F330 with Naza + GPS
Align Trex 550 with WKH, Trex 500 with Naza H
Tahoe Ed is offline        Reply With Quote
Old 12-19-2012, 03:45 AM   #4
FPVflyer
Thx for the help peoples, poblem solved himself, don't know why, but now it's working
Can close the thread, thanks to all
