Old 12-05-2012, 04:05 AM   #1
jchen
Default Helijive with Hacker Turnado
Hi Guys,
Need advice. I remember reading somewhere that the ESC has to be set
in KSA mode for Hacker motors. Was wondering if this applies to the Turnado
motor as well.
jchen is offline        Reply With Quote
Old 12-05-2012, 01:02 PM   #2
Magneto
I have heard of pilots using KSA with the Hacker Turnado .
Team
USA Team Minicopter
www.peakaircraft.com
Magneto is online now        Reply With Quote
Old 12-05-2012, 06:40 PM   #3
jchen
Thanks Magneto.
Old 12-12-2012, 11:59 AM   #4
ZuvieleTeile
I used a Jive 80 HV with a Hacker A50-14L on 12s for about 100 flights and no problems.
Maybe the problems arise only when pushing the limits . . .
Kind Regards ZT - TDR, Logo-400SE
No problem can be solved from the same level of consciousness that created it.(AE)
ZuvieleTeile is offline        Reply With Quote
Old 12-13-2012, 04:19 AM   #5
jchen
Thanks ZT. Will try out KSA mode first just to be safe .
Old 12-19-2012, 06:05 AM   #6
4cyclic
Have used a Turnado 470 with both 80 and 120hv Jive on mode 4, works great, no problems at all doing 3D.
4cyclic is offline        Reply With Quote
