| Engines and Mufflers Having problems or need advice on Engines or Mufflers? |
I just brought my srimok out from storage (6 months idle) and fired it up yesterday... It has a new engine with roughly 1 and a half gallons through it, and one lean out from a flight about 8 months ago where the fuel clunk didn't do its job.
The engine started up without a problem, flew pretty well (very rich, backplate cool) and I clicked in the high speed two clicks. It sprung to life, leaned out and then quit... The engine wouldn't start and had no compression. Afterwards I looked at the piston and it was heavily scored on the sides, the head was fine. Is this from storing it without preservative oil? Or did this simply happen from lean runs? would it be better to order and replace the piston and sleeve or get a new engine? Sent from my Galaxy Nexus using Tapatalk 2
Kasama Srimok FAIFA -Pyro 750- Mikado Logo 600SX -Pyro 700- Align T-Rex 450 -Paperweight-
Certainly no reason to replace the entire engine. Unless of course you're looking for an excuse
I had a lean run on my Srimok once because the fuel fill line to the tank (the line that's typically looped to the pressure release nipple) didn't have a good seal. My only gripe about the Srimok is the fuel line plumbing. One area where keeping it simple would've been nice. One line in for pressure, and one line out for fuel. Oh no, Kasama has to "innovate" everything. Four effing nipples just means four places I can lose pressure. Sorry...rant off. Since my lean run I use fuel line crimps on the four nipples to ensure I've got good seal. I'm not suggesting this is what happened to you, but wouldn't be surprised if it was.
Minicopter Diabolo-14s-Pyro 800-Kosmik-Vbar Kasama Srimok ECO CGY 750 Voodoo 400 Mini Prôtos CGY 750 |
#3 |
I haven't yet ruled out the fuel system... I only has time to tear down the engine before packing up for holiday travel. I plan on replacing the clunk, filter, lines and doing a rebuild on the engine unless I find further damage. It is quite unfortunate to have this happen, in already pigeon holed into favoring the Electrics due to flying field restrictions... oh nitro engines, why are you so Mich trouble? :p I wouldn't have kept it if the srimok nitro was less of a piece of art. I love this machine.
#4 | |
If you're still using the fuel line that's been sitting for several months I'd definitely replace them. Any leaks can cause a lean run. Bad fuel lines, dirty fuel filter, bad check valve, etc. can all be factors in a lean run.
