Go Back   HeliFreak > R/C Helicopter Support > Mikado Logo Helicopters > Mikado Logo 700 Xxtreme
Mikado Logo 700 Xxtreme Mikado Logo 700 Xxtreme Helicopters Discussion
Old 12-14-2012, 10:36 PM   #1
rcmarty
Default Servos , bls 451's ?
Just got my 700 last night
I have some servo's to juggle around to get things proper.
My logo 800 has a set of jr 8717's with about 250 flights @ 2s lipo.
I bought a set of 8917's on black friday.
My 600se is going to be sold - has a set of bls 451
Being the 8717's have been run in HV mode for 250 flights (700n + ~60 in logo 800) i'm starting to wonder if i should pull them out of the 800. Kyle is replacing there jr servo's at the 1200 flight mark but only at rated voltage. Couldn't offer any input on 8717 on 2s which i understand. I have a yardbird project i can fit these into.
So that leaves me with the new 8917's in the 800 , and i could swipe the bls451 out of the se. Of course i have a feeling that they might not be up to the task , and another set of 8917's are in my future .. lol
Flying aggressive 3d , with getting better cyclic management.
I can pull 3500 mah in 4.5 mins on the logo 800
Martin
Logo XXtreme 8917 / 256HV
Logo XXtreme 700 8917 / 256HV
Logo 600 : bls451/ 9256 , V-bar , QUK tail , Edge 623FBL , Scorpion 4035-500
Logo 600se : bls 451/251, QUK tail , Edge 693/105 , Scorp 5020-450 for sale
rcmarty is offline        Reply With Quote
Old 12-15-2012, 03:37 AM   #2
MrMel
V-BAR Guru
I would not hesitate to run bls451 in the L700 ive used them primary in many 700 sized
You can even push them upward with higher voltage too, they will survive that.
MrMel is online now        Reply With Quote
Old 12-15-2012, 06:44 AM   #3
sgrim80
I have 451s in my 700 and I'm happy so far :-)
Steve
#1 - Logo 600SX-THOR 10s 4400, YGE 90HV, Scorpion 4035-560kv on 12T pinion, BLS451/251
#2 - Logo 700-THOR 12s 5000, YGE 160HV VBar Gov, Scorp. 4525-520kv, BLS451/256
sgrim80 is offline        Reply With Quote
Old 12-15-2012, 02:11 PM   #4
surm
Default Futaba 255HV for cyclic for 700?
What do you think of Futaba 255HV for cyclic for 700?
Does anybody have such experience?
surm is offline        Reply With Quote
Old 12-15-2012, 02:14 PM   #5
bj660raptor
At what voltage? To the op i sent an email to futaba and got an answer they said the 451s are fine on 2s lipo,ill be using them this way on my 700 with a futaba hv tail servo.
Trex 700DFCHV,helijive,vbar 5.2 pro
Goblin 500 bls 153,bls 251,jive 100,pyro 600-12 20t pulley,mini v 5.3 pro
Rockin TP 65c and 70c and Futaba 8FGS.
Pilot Brandon J.
bj660raptor is online now        Reply With Quote
Old 12-15-2012, 03:22 PM   #6
MrMel
V-BAR Guru
Ive been flying mine at 8.4v
Old 12-15-2012, 08:33 PM   #7
sgrim80
I have been running them at 7.4 regulated and a bls256 on the tail.
Steve
Old 12-15-2012, 09:18 PM   #8
taosgraveyard
Wow.... Good to know!! I have been nursing my 451s along at 6V
Can a bls 251 also handle a 2s lipo?
taosgraveyard is offline        Reply With Quote
Old 12-15-2012, 09:54 PM   #9
sgrim80
A 251 cannot...hence my 256 purchase
Steve
Old 12-15-2012, 10:06 PM   #10
taosgraveyard
Ok.. my bls451 equipped helis, they are all using a bls 251
Rats
Old 12-16-2012, 12:13 AM   #11
OICU812
You can buy a Spektrum or WR Titan to drop the tail and still run the cyclics at 7.4+
OICU812 is offline        Reply With Quote
Old 12-16-2012, 12:27 AM   #12
rcmarty
Cool sounds like i can use the 451's
Shawn ..
What are you running for servos in your 700 ('s) ?
Any thoughts on the bls 451 on 8.4 ?
How has the tuning going ? Many changes from the stock XX software daefults ?
MArtin
Old 12-16-2012, 02:43 AM   #13
OICU812
I am using MKS HV 950s myself.
BLS 451s yea I ran them as well at 7.4 volts -8.4 volts no issues on a 700E Align ways back no issues.
File, well just PM me with latest email and I can send you the one I did b4 the big snow dump.
Old 12-16-2012, 11:18 AM   #14
rexxigpilot
I've got a Logo 700 on the way. I have a stash of servos I can use. I'd like some feedback on which is the best choice from those who use or have used them. It seems like the BLS451s are good for cyclic (and I have a set), but what about the rest?
Cyclic:
MKS HBL665
Futaba BLS255
Futaba BLS351
Futaba BLS451
Rudder:
MKS HBL980
Futaba BLS256
Futaba BLS251
I'm using the high voltage Futaba's in my Goblin 700. They seem to work well. I haven't used MKS servos before, but I thought I would give them a try. Any opinions on them are welcome. My other idea is to use the BLS351s (I've had them sitting around for a while) with the BLS256 tail. Thanks for the input!
rexxigpilot is offline        Reply With Quote
Old 12-17-2012, 01:21 PM   #15
bj660raptor
Rats
Perfect regulators has a pro version that takes 11.1 down to 5 for 15 bucks,thats the way my buddy Ben uses his 9256 and his 451s on a 2s lipo,so guess i wont be dropping 165 on a hv tail servo,i already have a 251 as well.
Pilot Brandon J.
Old 12-19-2012, 09:01 PM   #16
rcmarty
Is there any track record for the bls 451 on 2s lipo ?
I know they have been out for a bit now. I have several flights on my 6003d with a set with 0 issues , but at 5.6volts off a jive
I also have a bls 251 for the tail on the heli i'm robbing stuff out of also.
Or how about the 14s 10a WR bec (older version that doesn't do 7.4 v) set to 6v regulated and run the works on 6v 451/251. Would the 451 on 6v be enough for the 700 ?
Martin
