| Robird G31 RobirdUSA Factory Support Forum |
#221 |
These two places sell the ALZRC 3GYV2 version of the Robird G31 SRX cable....
http://www.rc711.com/shop/alzrc-3gy-...l?cPath=27_257 http://www.oomodel.com/alzrc-satelli...0-p-64018.html
Keith |
#222 |
Ok guys some help and advise needed. Just finished to mount and setup my G31 on a Trex 250 DFC...
I was spooling up and just at moment of take off the bird suddenly flip over and crashed ( I have started tail in). Wtf!! ![]() What i need to check or to adjust? Just impatient to make a simple stable hover with this little bird that are some months is on the shelf taking dust on it... Thks guys for an advise.. |
#223 |
First thing to check (and then double check, and then triple check) is that the swash is all moving in the right direction when you give input and that the corrections are corect when you tilt the heli.
#224 | |
I think is something related to sensibility in gyro.If needed I will post my settings. Guys new to setting up a FBL system ...so a lot of stuff to learn...Sorry |
#225 |
It won't move radical when you tilt, just make sure it is tilting the correct way.
Usually a death roll is an indication of vibration. Did you spool it up with no blades and check the vibe log? You can watch it in real time, that way you can go through the entire rpm range and watch the graph. sent from my phone using circus midgets
Tarot / Align 500e DFC (x2) ---Robird G31--- |
#226 |
Klaus,
A tip-over is usually one of two things - static or vibes. As LDH says on spool up it is usually down to vibes - check the monitor. I would try it without any blades on also to see what you get then. Another thing - how tight are your blades in the grips, they need to be slightly tighter than for FB. Cheers, Mike |
#227 |
X2 on the blade tightness. Try to have them as straight as possible before spool up. If your esc doesn't have a soft enough start and it jerks your blades back when you start up, tighten them till they don't kick back in the grips.
You basically want them tight enough that they dont swing back on spin up. They don't have to be perfectly straight as centrifugal force will true them up...but at low rpm they will cause excessive shaking if too loose. sent from my phone using circus midgets
#228 |
Thanks guys for your feedback. I have no time today to check it out I will do it and send immediatly the result.
From now I've learned two new things: Vibrations and tightness of blades... I was completly aware of these two things...Let me check out what is going on in my little beast. Thanks again guys. |
#229 | |
Is this your first FBL heli? If so, taking off with a fbl heli is different than with a fb heli. With a fbl heli you need to advance the collective in a quicker manner than you would with a fb heli. Don't move your cyclic stick at all when you're spooling up or the heli will tip over. FBL helis don't like to get cyclic inputs while they are on the ground. If you set up the blade pitch and FBL correctly then work on using collective only for take-off. Good luck! Last edited by SDedic214; 12-17-2012 at 05:15 PM.. Reason: spelling |
#230 | |
You impressed me a lot with your reply ...because I did exactly what you say giving cyclic at spoolup ...I came from mCPX world BUT this is REALLY the first one heli FBL of a "certain" size bigger than mCPX... Now you said "...If you set up the blade pitch and FBL correctly..." I've followed the instructions on the. ROBIRD soft. Now pitch curve ina FBL is the same as a FB heli? Expos? I putted mines at D/R 85 and Exp 50 and the swash it moves A LOT on cyclic stick movements and I know FBL ARE A LOT MORE SENSIBLE than FB helis... Any suggestion ?what must i do? Try to spool up only giving throttle?? and if it start to go on a side?? or in front AIL and ELE compesations are mandatory...to avoid a crash.. Illuminate me! thanks |
#231 | |
Ok, so here we go.... When you're getting ready to fly your heli start by placing the heli on a flat surface, skids down. Next, connect your battery and let the esc and gyro initialize. Your heli must be on a flat surface for the gyro to recognize the correct orientation. If you initialized your gyro at some odd angle the gyro will set your blades at an incorrect angle thinking this orientation is normal. If you flew with this your controls would be off and the heli wouldn't react well. If you accidently bump the cyclic stick at this time, the helis gyro will move the swash to correspond to the stick bump. Once you make a stick input the swash will stay where it was told to go. Unlike FB helis, a FBL heli will go in the direction that you move the stick until you give it another command. When I'm spooling up I try to keep my fingers close to the cyclic stick but not touch it. I advance my collective stick (aka: throttle, I'm Mode 2) in a smooth, continuous movement. Not fast but not slow either. I like to say "advance the throttle with authority". Once the heli is off the ground I then move my fingers to the cyclic and start flying. Pitch Curves: Since you're starting out I'd recommend the following Pitch Curves: Normal Flight Mode: 20% - 35% - 50% - 75% - 100% All other Flight Modes: 0% - 25% - 50% - 75% - 100% In Normal Flight mode starting out at 25% helps prevent blade strikes in case you slam the cyclic down hard. Other stuff: Its common for a heli to bank a little to the left in a hover so don't worry about that. If you've set up your FBL gyro correctly you should be able to lift off almost straight upwards (assuming no wind) with no cyclic input being needed. If you need to make swashplate leveling adjustments DON'T use the transmitter sub trims. Instead use the Swashplate Cyclic Center Adjustment in the Adjust menu of the G31. Your Dual Rate setting of 85% is fine but I'd lower the Expo down to about 20%. I hope that this works for you. |
#232 |
Hey guys:
Robird has just released a new software update with two small improvements:
Thanks, Scott RobirdUSA |
#233 |
Thanks Scott!
#234 | |
I didn't knew you were the owner of ROBIRDUSA...GOOD to know! Thanks again anyway! |
#235 |
I powered up my G31 today for the first time. It has software rev 98c. I have a DSMX sat rx. Found it will not bind to the G31. I now understand I need to find a RX that wil accept a DSMX sat and bind it to the TX through the doner RX. Is there any other way of doing the binding to the TX? OR am I going to be forced to purchase a new RX that has sat ports?
I have a AR7200BX with DSMX sat on my Christmas list and I think it is under the tree. Will I be able to bind the sat Rx I plan on using with the G31 with the AR7200BX or will I need something like the AR6210. When I power the G31 up the orange led on the RX flashes two or three times in rapid succession and goes out. LED 3 on the G31 comes on and blinks 8 times and goes out as LED 1 comes on steady. I have NO power to the servos. Obviously the boot sequence has failed. Is it dead because of lack of a bind on the Rx or could it be something else? RWW |
#236 |
Yes, you can bind it to your 7200. Just use the model you created for your heli w/ the Robird and bind your 7200 with the sat plugged in. Then you can use only the sat with your Robird and the ar7200bx on something else.
#237 |
Thanks LDH. Now all I need is for Santa to come through for me.
I hope you and your family have a Merry Christmas. RWW |
#238 |
Not a problem
#239 |
If someone said this, I apologize, the thread is long and I may have missed it.
If you are using a full RX with the Robird, it looks like you can't use the governor function. Is this right? (It looks like the plug that you would use for the throttle is used for one of the RX plugs.)
Gaui Hurricane 425 FBL with Robird G31 500 Class Rocks! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EFlight Blade 450 3D, Walkera Super CP Walkera Devo 10 w/ Deviation |
#240 |
If you are using a full Rx, the G31 has no control over the throttle channel. Without that, there is no ability to govern it.
Don Newman MAAC #82859 Align 250 Pro DFC, Tarot 450, EXI 500, Chaos 600 |
