Go Back   HeliFreak > R/C Helicopter Support > Outrage RC
Outrage RC Outrage RC - and XP Li-Po Factory Support Forum
Old 12-19-2012, 04:11 PM   #1
Grok
Default CY Ballistic FSO TT Gears in Fusion/Velocity
I decided to move the discussion of the use of CY Ballistic Steel TT Gears in the Fusion/Velocity 50 into its own thread.
The discussion started with a post 454 from NRS63 in the F50 pics thread. Pics are of a Russian heli F50 owner who managed to retro fit the CY Ballistic FSO Steel TT gears to the Fusion. Presumably you could also do it with the Velocity. The gear he is using are these. It looks like you will also need to purchase these. NRS63 provided a link to a Russian site that explains things a little better. I translated the text using Chrome which only slightly helped clear things up. It looks like he had to make use of a lathe to get the gears to fit. Here's a pic of the mods.
I can barely make heads or tails of what parts he's modifying.
Grok is online now        Reply With Quote
Old 12-20-2012, 01:23 AM   #2
NRS63
Grok, Please change a picture for another-this has wrongly got on a site, I now shall change on correct
....The acquired mind does not compensate the stupidity given at a birth....
NRS63 is offline        Reply With Quote
Old 12-20-2012, 02:03 AM   #3
Grok
Changed to the new pic. Thanks.
Old 03-31-2013, 04:21 PM   #4
NRS63
Here 19 flight, I try to adjust Flajbarless, all works very well.
At us winter, cold, +3 degrees of Celsius
