Old 12-19-2012, 08:20 PM   #1
Seasick78
Default MUI 150 sensor?
Does anyone have any photos of one if these sensors installed? Any feedback on how accurate they are?
Team - "Self Interests" -
Flying what I want to, simply because I enjoy it!
Seasick78 is offline        Reply With Quote
Old 12-19-2012, 08:56 PM   #2
Kiba
I've got a MUI200, MUI150, and MUI30 on hand but haven't installed them yet (waiting for the receivers to make the changeover from Spektrum to Jeti.)
You wire the heavy wires in line with the positive wire of your ESC for amperage, for voltage there are two small wires that you connect across the flight pack positive & negative, and then there is the wire with standard servo connector to the receiver telemetry port. The units themselves are only about the size of a quarter.
I used bullet connectors in line on the positive wire of the ESC so I can run my YGE with or without the MUI installed. I also used the Jeti anti-spark bullets-- very nice! I may eventually change to a Mezon 130 for wiring simplification.
I would guess the MUI itself is quite accurate, at least comparable an Eagletree. The limiting factor for pack consumption accuracy displayed on the TX will probably be the telemetry link update frequency rather than the accuracy of the MUI itself; I'm not sure what the refresh rate is of the Jeti telemetry. That's also assuming all the calculations are done on the TX from instantaneous voltage/amperage data from the MUI. If the refresh rate of the telemetry is low (say 1hz) then the mah consumed wouldn't be very accurate as flight pack voltage/amperage is a very dynamic parameter. However, if the MUI monitors the pack consumption calculations on-board at a higher refresh rate, buffers it, and then sends that data to the TX at the lower telemetry refresh rate that would be far more accurate than the first scenario.
I'm not sure how Jeti handles the MUI telemetry so it's hard to say. I guess I'll find out once I have my receivers and I'm flying with it!
Minicopter Diabolo - BD Axon, Kosmik 200, Jlog 2.6, Xnova XTS 4530-480, 14S 4500, BLS255HV/BLS256HV
Bergen Magnum 44 -
BD Axon, Wren MW44 turbine, BLS156HV/BLS256HV
Jeti DC-16
Kiba is offline        Reply With Quote
Old 12-19-2012, 10:15 PM   #3
Seasick78
Any pictures you can take of the uninstalled MUI 150?
Old 12-20-2012, 12:40 PM   #4
Jotto
As far as I have understood, the mAh calculation is done on the MUI itself. The cumulative mAh consumed is sent to the transmitter. The capacity alarm threshold is also defined on the MUI, and an alarm code is sent to the transmitter when the defined capacity is exceeded. At least that's the way it works with the JetiBox.
I forgot to turn on the JetiBox the other day. I turned it on mid-flight, expecting the mAh counter to start at zero. But no, the counter started at some 1000 mAh, which was the amperage consumed since I connected the battery on the model!
Jotto is offline        Reply With Quote
Old 12-20-2012, 01:17 PM   #5
Kiba
That was my assumption as well; as much thought as Jeti puts into things it would make the most sense for accuracy and packet size reasons to do all the calculations/buffering on the MUI itself and then periodically send that data via telemetry. If the TX or JetiBox did all the calculations the refresh rate between the MUI and the TX would have to be very high to maintain a reasonable level of accuracy.
Your impromptu test of forgetting to turn the JetiBox on and then finding it at 1000mah during the middle of the flight is enough evidence that the MUI does all the storage/calculations on-board and then sends out periodic telemetry updates.
Bergen Magnum 44 -
Jeti DC-16
Old 12-20-2012, 01:45 PM   #6
Seasick78
Very nice!
Old 06-11-2013, 04:31 PM   #7
tribe3
So the MUI replaces the positive wire on the ESC to say? Can I cut the MUI wires shorter? I want to avoid cutting the ESC pos as much as possible
Minicopter Diabolo 800+ - Minicopter Triabolo - Srimok FAIFA
Jeti DS-16
tribe3 is offline        Reply With Quote
Old 06-11-2013, 11:18 PM   #8
desertstalker
You can cut them as short as you like.
-DX8
desertstalker is offline        Reply With Quote
Old 06-12-2013, 03:27 PM   #9
Sanction
Here is a picture
Sanction is offline        Reply With Quote
Old 06-13-2013, 09:19 AM   #10
rchelijc
Just out of curiosity, why positive and not negative? Would it work if connected in-line with the negative?
SRIMOK 90E Faifa TJ VBAR HK-4525-UE
SRIMOK 90E Faifa Ellie VBAR P700-520
PRÔTOS 500 Brain HK-3026
PRÔTOS 500 StretchVbar HK-3026
rchelijc is offline        Reply With Quote
Old 06-13-2013, 08:24 PM   #11
desertstalker
It is designed to work on the +ve lead, since it has voltage measurement as well it may not work correctly on the -ve lead.
-DX8
Old 06-13-2013, 08:32 PM   #12
cbdane
I believe it should work in either lead. Of course the current is the same in both. The current sensor is most likely a Hall effect style (Allegro, etc.) with no electrical connection between the high current path and the rest of the circuit. That's why there are completely separate voltage measurement + and - wires.
Have laser, will travel.
cbdane is offline        Reply With Quote
Old 06-14-2013, 12:45 AM   #13
desertstalker
theoretically, but since the instructions show it hooked up to the +ve I was not game to risk cooking the electronics if it turns out the main lead and red wire are actually connected.
-DX8
Old 06-14-2013, 05:51 AM   #14
ArguZ
Honestly...dont bother with the MUis
Get yourself some UNISENS-E from SM Modelbau and you get Capa, Voltage, Amps plus RPM and Altitude all in one sensor.
I only have a MUI on the Hexa because this one also has the GPS.
But for the Helis and planes I am all SM now.
http://translate.google.com/translat...16e656&act=url
ArguZ is offline        Reply With Quote
Old 06-14-2013, 07:55 AM   #15
Puttputt maru
Does it measure capacity used ?
Are the displayed values names in English ?
Not sure if they have changed that.
TDR-IIto build, Triabolo, 2 X TDR, Kasama Srimok,90e FAIFA, T-Rex 700e DFC, Goblin700, BD 3SX, Jeti DC-16, Mezon,HW,Kosmik
CompArf 330 SC 2.6 BME 110, Ultimate Aeroworks 20-300, DA 170, CB200, Cortex, Q80-8M in a 91" EF Extra ++
Puttputt maru is offline        Reply With Quote
Old 10-29-2013, 10:22 AM   #16
johnjonfenomenon
how do you install an MUI on a multirotor with 4 esc? I have a qav 500 and I use 2 packs in parallel to make a 8,000 mah pack? how do I wire it? I was told that to get the proper MUI i should add up all the amps and go to the nearest MUI, so I have 4 30 amp esc's. Hence I went with an MUI 150. But can I just simply solder this to the board and replace one of my red leads for my battery connection? Also I have 2 power leads one for each battery that taps direct from my board. how should I wire this?
After every crash just remember .. “We can rebuild him. We have the technology. We can make him better than he was. Better..stronger..faster.” Intro from Six Million Dollar man
RIP Roman Pirozek Jr. 1/11/94 - 9/5/2013
johnjonfenomenon is offline        Reply With Quote
Old 10-29-2013, 10:47 AM   #17
Seasick78
I have several of these installed now. Setup is no different than any other system. Just wire it between the pre-existing power lead and the battery. I'd take pics for you but I would have to disassemble my Phantom.
Old 10-29-2013, 11:00 AM   #18
psylence519
With 2 power leads you have a problem. The MUI needs all power from the batteries to run through it to be able to monitor it.
I would remove the dual power leads, replace with a single negative wire and a single positive wire with the MUI spliced in. Then just use a parallel adapter close to the batteries. Kind of a pain but there's no other way for the MUI to see all the current.
X5 / Goblin 500 / Goblin 700
psylence519 is offline        Reply With Quote
Old 10-29-2013, 12:33 PM   #19
Seasick78
+1
I missed the comment about two power leads.
Old 10-29-2013, 03:02 PM   #20
Mr.Gobler
OH this looks neat! Should give this a try..
http://www.alignrccdn.com/
Mr.Gobler is offline        Reply With Quote
