| 300X Blade 300X Helicopters Information and Help |
#21 | |
http://www.hobbypartz.com/33p-solarservo-d658.html |
#22 | |
http://www.hobbypartz.com/33p-solarservo-d654.html
-Chris |
#23 | |
Ah! Thanks Chris...for some reason I couldn't find it last night....late night web searching isn't the best way to do it ![]() Yeah, the Solar 654 can't be beat as a replacement for the stockies in my book. pretty much the same, just with metal gears...and a touch heavier (and actually tighten up the rear servo area, eliminating the need for the shimming that some are doing back there |
#24 |
Awesome thanks!
Blade mCPx BL, Blade 130X, Align Trex 250 SE,Blade 300x,Align Trex 450 Sports! Spectrum DX8 |
#25 |
I have pretty good results with Align DS415m. Not too expensive, all metal gear and fast. It's a perfect fit, real tight so it also takes care of flexing to some extent.
#26 | |
Just went to LHS and picked up 3 align 410m was wondering what your useing for a tail servo?
Trex 700n DFC Beast x...Trex 600n Beast x... Trex 450 pro V2 DFC Beastx KDE XFC Ice lite 50 MCPXs'' HPO7..HPO5s..CO5m..V2 stock..Nano Cpx Blade 300x Phoenix 25esc Park BEC Blade upgrades Ducati Desmo 1/5 scale nitro superbike |
#27 |
The Align DS425M works great on the tail.
cheers, TomC
Blade mCPX-BL,300x,450x,500x,550x(hc3sx) Logo14, 550 blades TT X50E, 10s, HC3-SX Ion-x, Actro 32-3, SS, 10:1, PJazz esc, 10s |
#28 |
#29 |
I use the Hyperion ds11-gcb on mine. It's about as fast as you can get in the price range (with decent reliability) and has worked very well on all the helis I've used it on, including the 300X. Also, I'm not a fan of metal gears on tail servos, as the slop that inevitably develops in them has a much more detrimental effect on tail performance than it does on the cyclic.
MARTY Team Newb pilot Trex 500 fbl -Tarot 450 Pro fbl- Trex250 DFC fbl - 300X - 130X X3- mCPX brushless X3 |
#30 | |
Team Newb Pilot 450X (6S Scorpion 2221-2010, Spektrum H3000, MKS DS95i, Ice Lite 50); 300X (Spektrum H3000, Hyperion DS11GCB, HiModel Cool 33A/Don's RC Wicked 4800kv); TRex 250 Pro DFC (250MX, MicroBeast, Phoenix 25); 130X HP10S; mCPX BL; NanoCPX. |
#31 | |
#32 |
Yes you do as the servo splines are a little bigger on the H3000 servos than they are on the stock servos. I use one of the 4 way servo arms and lined it up and selected the proper hole using the stock servo arms as a reference. It also takes a little bit of doing to get the servo linkage ball into those arms as the screw on the ball is a bit bigger than the hole on the servo arm. I widened mine a bit using a small phillips head screwdriver and then they went in with a minor amount of force. If you would like to see pictures of my particular setup (not that it's necessarily perfect but at least flies well), let me know.
#33 |
Managed to do a servo gear change without problems, so thanks again you experienced guys, I would have just gone out and purchased a new servo.
![]() If I can do it then anyone can, didn’t even remove the zip ties on the wiring.
Blade MSR, NANO, MCPXv2, SR120, MQX, SR and 300x with a DX6i Kev |
#34 |
I saw a guys yesterday who had fitted Hitec 5065MG into the Blade 300x without an issue....
