Old 09-29-2012, 03:32 PM   #21
craig1980
They should have mine on Monday so I hope to hear something next week. I will update you guys.
craig1980 is offline        Reply With Quote
Old 10-05-2012, 01:09 PM   #22
Gscott
YS has to have seen a few of these by now. Any updates?
Gscott is offline        Reply With Quote
Old 10-05-2012, 06:38 PM   #23
craig1980
Tracking shows they recieved mine on 9/28. No communication from them yet.
Old 10-12-2012, 08:43 PM   #24
craig1980
Update. Well no update really. End of week two with no motor or communication
Old 10-13-2012, 10:25 AM   #25
Gscott
That's not good. I finally sent mine on Thursday. Have you tried contacting them for an update?
Old 10-13-2012, 08:07 PM   #26
craig1980
No I haven't called. I figured I would give it another week. I work a ton of hours myself so I am very understanding of a busy shop.
Old 10-15-2012, 04:29 PM   #27
fastone93
Sorry for the long silence guys, but my issue was finally solved today. I received two new in box engines after a couple of firm conversations with YS. Not happy with this engine design and do not plan to keep them, but you couldn't ask for much more from an engine manufacturer as far as service goes.
Trex 700 dfc (OS 105HZ-R, Hatori Pipe, MKS HBL950, Futaba CGY750, MKS HBL980, Rail Mains, Rail Tail Blades)
fastone93 is offline        Reply With Quote
Old 10-16-2012, 09:46 AM   #28
Gscott
Did they ever say what caused the issue? If you could expand on your conversation with YS that would be great since several of us will soon be in the same boat.
Old 10-16-2012, 10:13 AM   #29
fastone93
I was told that the problem came from my setup, which hadn't changed in 2.5 years except for these new engines. "Something in your setup is generating heat" obviously it is the engine...
I received a call from YS and was told that the crank and case had been replaced and it was shipped that day. I told the gentleman that I wasn't going to accept a 3 week old engine that obviously had metal go throughout it's internals and I wished he would have called me like he said he would, before any repairs were made, and oh yeah, by the way my other engine is on it's way to you right now. I said that at a minimum the case, crank, piston, ring, liner, and bearings needed to be replaced. His response was that is pretty much a new engine, and I agreed. I said I would accept nothing less than new engines. He said that he would think about it, and I said that I was going to refuse the package that he had shipped. I called him again after he had both of my engines in hand, we had another discussion pretty much the same as the one above, and I received new engines.
Old 10-24-2012, 08:37 AM   #30
Stevendavis
I realy wanted to try one of these, but now I think I'll have to stick with the OS 55 for a while. Maybe YS will get these right in a year or so.
Stevendavis is offline        Reply With Quote
Old 11-01-2012, 08:05 PM   #31
craig1980
Well I got mine back two days ago. No explanation and no communication unless it was me calling them. New piston, sleeve, and rear bearing. Only good news is I just got home from trading mine for a 55hzr. Did the trade with a guy from the local field. He was there when mine blew so he knows the whole story so I feel good about the deal. Good luck guys
Old 12-07-2012, 03:07 PM   #32
gotoyogesh007
guys need your advice, I am planning to buy YS 60SR
gotoyogesh007 is offline        Reply With Quote
Old 12-11-2012, 03:42 PM   #33
Bobs
My advice - Don't. I have a YS 56 with continual tuning problems and two YS 120s, one of which is on its way to YS for repair: a 3/4 inch long by 1cm wide piece of the piston broke off. And I'm not the first one that's had this problem. My motor temps have never been above 186 degrees right after a flight and my head speed on the 120s is 1920 to 1930. The motor I sent in for repair was purchased in April. It was easy to tune for break-in, started right up and had gobs of power, that's why I bought a second one this fall. After reading this thread I'm concerned that the other 120 is doomed for failure too. I shipped mine off to YS one week ago and know they received it last Friday. Haven't heard anything yet and hope it's a lot sooner than some have posted here. Good luck if you purchase a YS60.
Bobs is offline        Reply With Quote
Old 12-21-2012, 11:33 AM   #34
gotoyogesh007
Sad to hear that Bob will stick with YS 50 for some more time until YS fixes all the bugs they have with YS 60 SR .
"Wish you a Happy Christmas".
Old 01-13-2013, 02:08 AM   #35
jody
Default YS 60SR - very frustrated.... UPDATE
Having good results with this one on the Hatori 60 muffler so far
Team Old Mate - He's a good bloke
jody is offline        Reply With Quote
Old 01-27-2013, 05:25 PM   #36
bhush101
Default YS120 with OS carb modification
http://www.youtube.com/watch?feature...&v=A4s2NhNTuz8
bhush101 is offline        Reply With Quote
Old 02-01-2013, 11:53 AM   #37
jwatts007
Originally Posted by bhush101 View Post
With OS carbs you adjust the needles too get them too run...with the YS you adjust them too tune em....
jwatts007 is offline        Reply With Quote
Old 04-14-2013, 02:55 AM   #38
3D Tommy
I have bought an ys 60, since 4 weeks ago.... I fly Velocity 50N2 with Msh Brain and the GOV of the brain.... Fuel is 30% Rappicon...
I have no Problems with this engine,he is running very very well and the power.....
3D Tommy is offline        Reply With Quote
Old 04-22-2013, 10:11 AM   #39
Frankcm1
I had the exact same thing to happen to me. I was running very rich with fuel spitting out of the muffler. I was in a hover and then suddenly I heard a pop sound and the engine cut off. Was not able to restart it. This has been 3 weeks of frustration with this engine. I hope it's not blown already.
_________________________________
Trex 700N w/SK540, Trex 600N w/BeastX, Fusion 50 w/IKON, Goblin 500 w/MiniVbar, Spektrum DX8, RF6.5
Frankcm1 is offline        Reply With Quote
Old 04-26-2013, 12:35 PM   #40
codfish124
send me a pm with your phone number ill have Buzz give you a call about the os carb mod i know hes got a few running on the 60 with great results
Magnum fuels, Heli Port Hobbies,
THE NEW MAGNUM ENERGY 75C BATTERIES
codfish124 is online now        Reply With Quote
