Old 12-21-2012, 02:37 AM   #21
Bonkievan
Originally Posted by ChasCS View Post
Truer words were never spoken, perhaps whispered a few times though. Smile
But yeah,,,.
Tareq Alsaadi - Alpine Heli Smackdown 2011 (# Crash #)
www.youtube.com/watch?v=YIOwHURs4-I
Chas
Just a normal flight for the "King of Smack", then.
How is the 700 build going?
Trex700 DFC HC3-SX
Trex550 DFC(V2) 3GX
MCPx V2
DX8
Bonkievan is offline        Reply With Quote
Old 12-21-2012, 06:20 AM   #22
EC225LP
hey... anyone using the new 3.0 with DSMX sats?
I was using 2.1 on my 550 with DSMX sats but the bind light kept flashing, even when the system was bound....
I didn't like it so changed to DSM2 sats- problem solved.
EC225LP is online now        Reply With Quote
Old 12-21-2012, 10:23 AM   #23
RV_7A
Yes I am using DSMX sats with my 3.0. No issues.
Jeff B
RV_7A is offline        Reply With Quote
Old 12-21-2012, 12:11 PM   #24
Bonkievan
Jeff B
+1
To the EC225LP. What Tx are you using? Have you checked the Frame Rate settings etc?
Trex700 DFC HC3-SX
Trex550 DFC(V2) 3GX
MCPx V2
DX8
Old 12-21-2012, 12:14 PM   #25
rcflyerheli
Originally Posted by Bonkievan View Post
+1
Will it take the 11ms?
Goblin 700, Vbar Silver - Trex 700 V2, Vbar - Trex 700DFC, Vbar Silver - Gaui X7, Vbar Silver
Trex600EFL Pro, Vbar - Trex 600 ESP, Vbar - Trex 500 ESP, SK 720 - DJI 550, GPS
rcflyerheli is offline        Reply With Quote
Old 12-21-2012, 01:24 PM   #26
Bonkievan
I was just trying to get some more info as it's impossible to give an answer without it.
Personally, I don't think it was an issue with the sats, rather the set up/bind prodedure of tx sats.
But as I said 'we need more info on setup'
Trex700 DFC HC3-SX
Trex550 DFC(V2) 3GX
MCPx V2
DX8
Old 12-24-2012, 10:18 PM   #27
EC225LP
+1
Hey.... Im using dx8 i tried both, 11 and 22 but still had the flashing bind light....
I was going to update later today but just crashed my 550 into a pond and all the electrics are ruined... Lol
Sent from my GT-I9070 using Tapatalk 2
Old 12-25-2012, 07:31 PM   #28
Dino Spadaccini
the 3gx does not like dsmx on sats you need to use a rx
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba
Dino Spadaccini is offline        Reply With Quote
Old 12-25-2012, 07:46 PM   #29
jstan
Default 3GX doesn't like dsmx?
Dino - Can you elaborate a bit on this please? I never read about this being an issue and just completed my first build...a 700 with the 3GX and 2 dsmx remotes. I've had about 10 flights, so far. Should I be concerned? Thanks.
jstan is offline        Reply With Quote
Old 12-25-2012, 07:50 PM   #30
Dino Spadaccini
the 3gx has the coding in it for dsm 2 not X not sure how you got it to work what radio are you using i have seen binding issues and at times thats why i stated run the wire to wire with an RX
Old 12-25-2012, 08:43 PM   #31
jstan
Default DSMX Sats
I read through the manual before config/ordering and under: JR/Spektrum Connectivity, is says both sats need to be the same type. Point number 3 states that "3GX supports all satellite receiver models on the market today...."
Since I have bound and been flying...do you think that I am ok? The manual is very clear, but don't really want to see my new baby augered into the earth.
- Jeff
Old 12-25-2012, 09:04 PM   #32
RV_7A
- Jeff
I can confirm that. I initially purchased 2 new DSMX sats for my new 700E combo with the 3GX v2.1 and have since upgraded to v3.0. No issues and I get a solid link light on both sats.
Jeff B
Old 12-25-2012, 09:05 PM   #33
Dino Spadaccini
let send an email to the designer and see
Old 12-25-2012, 09:35 PM   #34
jstan
Default DSMX Sats
Thanks...In addition to the 700, the receiver on my 550 was bad and I was planning on using the 2 sat method with that also.
- Jeff
