Old 12-07-2012, 06:17 AM   #141
Kendo
Originally Posted by timox72 View Post
Well, the stock collar needs that because of it's thickness. The MSR head links have a much smaller diameter so the whole "msr-collar" rests on the inner part of the bearing
Didn't think of that. Sounds perfect, thanks timo.
Kendo is offline        Reply With Quote
Old 12-07-2012, 11:41 AM   #142
timox72
You're welcome Kendo
timox72 is offline        Reply With Quote
Old 12-07-2012, 12:07 PM   #143
timox72
Originally Posted by mixfisto View Post
Is it possible to post up a pic?
Sure mate, here they are.
Btw the collar must be set at 22.70mm, measured from top of the shaft to bottom of the collar. Anyway I would check 0 pitch again after this little mod.
ID:	371972   Click image for larger version
Old 12-07-2012, 12:47 PM   #144
Kendo
What's the key to making the top cut outs on the shaft perfect? Would getting it wrong make the head sit off centre? I made a shaft but can't tell if its the shaft or the head, I'm suspecting my head is crooked.
Old 12-07-2012, 02:27 PM   #145
timox72
Making it perfect is almost impossible I guess. I use the cut of head link as a stop on the main shaft.
For example if the cuts need to be 7mm long you just mount it on the shaft 7mm from the top of the shaft. Filing down the flat spots is just a case of filing and measuring all the time, nothing complicated.
Btw 7mm is just an example, donīt start filing already
Old 12-07-2012, 02:46 PM   #146
Daryoon
Time for Jim Stoll to make one of his main shaft jig for the nano. The mCPX version has the part that helps you file down the flat end. Anybody contacted Jim Stoll yet?
Daryoon is offline        Reply With Quote
Old 12-07-2012, 03:22 PM   #147
timox72
Absolutely right, time for a Jim Stoll jig Donīt know if anybody contacted him though, guess Iīll PM him right now.
Old 12-11-2012, 06:33 PM   #148
slim hank
Default nano servos????
where can you buy new servos??????thankls hank
slim hank is offline        Reply With Quote
Old 12-14-2012, 10:28 PM   #149
Heli biggie
Rcdepothobbies.com has them.
I just got my new main motor. I would have went brushless but im not set up to solder stuff that small. Im just happy to have my nano working again, .
Flight video of my 450'and 600 from today at ninja636king@youtube.com
Trex 600 efl pro , v450/align, Nano cpx
Heli biggie is offline        Reply With Quote
Old 12-19-2012, 08:26 PM   #150
jim_stoll
Hey Guys - coming off another crazy work period (coinciding with the end of the semester, and the beginning of our winter holiday :-), so trying to catch back up on things. Just saw a PM from Matijin from earlier this month. I'm definitely up for making a jig for the nano, if it looks like something that could be useful.
Can someone send me dimensions on the shaft, including length, diameter, measurements on any features on the shaft (position, length and depth of flat spots, diameter and placement of holes, if any). I'm going to be away for a week or two over the holiday, which is bad in terms of getting anything built, but good in terms of having time to think through a design, so if someone can send me specs, I'll see what I can do.
Thanks!!
Jim
Wife, V1, All Stock (missing manual)
Kid, V1 & V2, Xtreme Attitude, Gyroless, Full Metal Head
Dog, V2.1, Brushed, Slightly Modified
Horse, V3, Grasser, Continuous Restoration Project
jim_stoll is offline        Reply With Quote
Old 12-20-2012, 10:35 AM   #151
SHYguy
LOL! Best sig on HF there Jim!!!
Blade 2x nCPx Mild B/L, 2x mCPx dual B/L HP06V2, mCPx HP05S, 300X stockish, 300X Lynx/RKH/Wicked/Turnigy, 450X iKON, 6S T-Rex 450 V2, T-Rex 700E 3G BD3SX, Spektrum DX6i & DX8, Phoenix sim. 5 foamies. Way too many RC cars. Way WAY too little time!
SHYguy is online now        Reply With Quote
Old 12-20-2012, 05:10 PM   #152
bmc76
Originally Posted by Brian James View Post
• Swashplate linkage lengths – 25mm
Anyone else notice that the rear servo link is not 25mm? The servo is mounted a couple of mm above the other 2, to get it to 25mm you would have to back it out several turns and your swash would be way off. I adjusted the side links to 25mm and set the rear by getting 0 pitch at mid stick.
T-Rex 250 Pro DFC with Beastx / ZYX-S Powered 130x with HP08- XP-12a / 300x with Don's Wicked / 450x / DX8 / Real Flight 6.5
bmc76 is offline        Reply With Quote
Old 12-21-2012, 02:51 PM   #153
pommesschranke
Default Blade nano cpx .spm file for all DX7s owners
I posted my file here:
http://www.helifreak.com/blog.php?b=1987
mcpx, T-Rex250, Blade400, HK450GT, mini Protos stretch.
my sim: http://www.heli-x.net/
pommesschranke is offline        Reply With Quote
Old 12-26-2012, 08:16 AM   #154
franklin_m
Default Settings for Futaba 9C w/ DM8 module?
Shot in the dark here, but just got a Blade Nano CPX yesterday...I see the settings in the manual, but wanted to see if someone had exact settings for a Futaba 9CHP w/ DM8 module.
Thanks!
Frank
If at first you don't succeed....
then carrier landings are not for you !!!
"Fly Navy"
franklin_m is offline        Reply With Quote
Old 12-26-2012, 04:19 PM   #155
dragnse7en
Post
Here's 2 how-to videos I made to get the KBDD mCP X skids to fit our nCP Xs -
This video shows how to cut them down and install them to the main frame:
YouTube
"> YouTube
" type="application/x-shockwave-flash" width="425" height="350">
This is a follow-up video, as I had problems using foam cut to size to secure the battery. The 2nd video is a nice and sweet solution to fix that:
YouTube
"> YouTube
dragnse7en is offline        Reply With Quote
Old 12-27-2012, 01:13 AM   #156
tmacrc
Default Nano CP X Battery Placement
Hi, Just got the Blade nano CP X. It is my first heli. Flying it with a DX8.
Is there a correct way to install the battery on the nana CP X?
They don't really show how the battery is to be installed in the english manual.
Battery keys up or down?
All the way in or just part way into the holder?
All the way in seems to make the heli front heavy???
anyway, Thanks.
tmacrc is online now        Reply With Quote
Old 12-27-2012, 05:51 AM   #157
dragnse7en
anyway, Thanks.
Insert the battery pack all the way in, with the keys facing down
Old 12-27-2012, 06:12 AM   #158
SHYguy
Sweet'ol RC10 in the background there!!!
Old 12-27-2012, 07:28 AM   #159
Heli biggie
I hope everyone had great holiday so far, my question is if i have a rtf nano with stock tx, can i use that tx and get a 130x???? Does anyone have setting for that?? I may buy a xmas heli! If this works out!
Old 12-27-2012, 10:00 AM   #160
SHYguy
Get a new or used DX6i, the sooner the better!
