Go Back   HeliFreak > R/C Helicopter Support > 800 Class Helicopters
800 Class Helicopters 800 Class Helicopters
Old 12-14-2012, 12:26 AM   #1
nu66ie
Default New 800e Trekker Video
Finally got a friend to shoot some video of me flying the 800e. The video is a combination of two flights. The second flight at the 4:35 mark is a little more zoomed in.
If anyone would like to see the Vbar settings, PM me and I'll send them to you.
Vbar 5.3
pitch is ±10.8
take off head speed - 1580 - stunt head speed is 1950
governor gain - 17
timing - 12
pwm - 12
GensAce 5300mAh 60c
T-Rex 800e DFC Trekker w/VBar, Blades MCX2, 120SR, Radian Pro, DX8's.
nu66ie is offline        Reply With Quote
Old 12-14-2012, 12:36 AM   #2
GRIMX
Thats one big bird, nice flying
T-Rex 600 EFL PRO,KDE XT MAIN ROTOR HEAD SYSTEM. DFC600 Swashplate.
SPEKTRUM AR7200BX DS610 X3, DS650 X1, Phoenix Ice2 HV 80 ESC. KDE600XF
GRIMX is offline        Reply With Quote
Old 12-14-2012, 09:46 AM   #3
hidaven
Don, I thought you settled on 1900 for the H.S.? How are you liking 1950? I'm running mine governed @1900 but think I have headroom in the cc to bump up to 1950.
Dave
hidaven is offline        Reply With Quote
Old 12-14-2012, 11:07 AM   #4
HeliGriff
Great job, Don! Enjoyed it very much!
ALIGN T-REX 800E DFC TREKKER
ALIGN T-REX 600EFL PRO DFC
ALIGN T-REX 450PRO DFC
Spektrum & MicroBeast electronics
HeliGriff is online now        Reply With Quote
Old 12-14-2012, 11:24 AM   #5
nu66ie
Thanks GRIMX, and HeliGriff !
hidaven
I did run 1950 for a while but I needed just a bit more overall agility and didn't want to increase the pitch. It's amazing how just 50 RPM will change the performance of your heli. I went up 10 RPM at a time and stooped at 1950. If I remember correctly I could take it over 2000 and castle still had some headroom. I did one flight at 2000 and it was a little nerving at the sound and speed.
The landing HS is 1580 with +6 -2°
Old 12-19-2012, 06:49 AM   #6
Scorny
Dear Lord....
I can never get used to that sound.
Nice flying and thanks for the vid.
Scorny is offline        Reply With Quote
Old 12-19-2012, 06:43 PM   #7
nu66ie
Thanks, that sound is pretty amazing isn't it? I can't wait to put a set of Edge 813's on it... It will be even louder. When I get the nerve to fly down low, it's even louder. Kind of addicting And seeing that long tail boom swinging around, this bird provides allot of unique visual and audible sensations. Yea, I'm kind of weird like that.
Old 12-19-2012, 07:08 PM   #8
HeliGriff
Music to my ears!
Old 12-19-2012, 11:57 PM   #9
hidaven
Are you worried about tail blade strikes with the edge 813s?
Old 12-20-2012, 12:17 AM   #10
ChasCS
Default "Simply Irrisistable"
Hi,
I've watched this video several times since you first posted it with the thread.
I hope that you will record many more.
I Finally got the courage to say how envious I really am of you.
Great flying obviously, with your well practiced technique, and what an incredible big beauty.
Good times are ahead for you.
Enjoy that wonderful helicopter.
I wish, some day... I'd be more than happy with just 1/4 of your skills friend.
Ah, please carry on!!
By the way, I think those reflective bits look quite brilliant on your blade tips.
I will definitely be applying some to my 700 E..
Chas
Parrot AR Drone 2.0~iPad 3
hpi 106364 Savage X 4.6 Big Block Charger R/T~DX3s
Blade mQX \ Heli-Max 1SQ~DX6i@AnyLink \ Traxxas QR-1 {RealFlight 6.5@Phoenix ENVY}
Align TRex 700E 750MX (530KV) DFC HV Castle Phoenix ICE2 HV 120 3GX 3.0~DX8
ChasCS is offline        Reply With Quote
Old 12-20-2012, 09:10 PM   #11
nu66ie
Smile
hidaven
No worries about clearance. There is at least 30mm clearance now with 800mm blades so the additional 13mm will clear with no problem. Will have to keep fresh dampers installed and the blades tight.
ChasCS
Thank you for the kind words...It is encouraging and inspires me to keep at it. There is a ton of simulator time involved, but in the end, that beast of a heli does all the work.
Here is the prismatic tape I use. It holds up very well and is very thin. Use windex to apply them and smooth it out with a soft cloth. I have the wide strip on the tips on the top of the blade and a smaller strip on the inside of the bottom of the blade. This way I can see either a large rainbow circle (top) or a small rainbow circle (bottom) giving me instant orientation.
Old 12-22-2012, 12:00 AM   #12
Sladex
Wow, nice heli you got there .
Trex 700E V2 - Canomod Phantom V2 Canopy, AR7200BX, CC BEC PRO
DX8!
Sladex is offline        Reply With Quote
Old 01-03-2013, 12:27 AM   #13
Tim@AssuranceRc
Looks good! Nice flight!
Align USA
3626 Briggeman Dr
Los Alamitos CA 90720
562-598-4700 x10
Tim@AssuranceRc is online now        Reply With Quote
Old 01-03-2013, 01:39 PM   #14
hidaven
Tim, instead of watching videos, why dont you and your friends figure out why this pathetic head design keeps wearing out the DFC dampners and feathering shaft sleeves????? And seriously Tim, if there were inherent problems with the DFC 700 using the existing white gears what makes you think they would be any better under incresed loads of the 800? From the crappy OWB block to the undersized skids, to the ABSURD prices for replacement parts?
Align needs to admit their mistakes and solve these issues FREE OF CHARGE. yes, like most respectful AMERICAN companies do........
Old 01-04-2013, 07:57 AM   #15
Dino Spadaccini
hidaven what is your setup on the 700 dfc you own or 800 you own I like to see a pictures of your dfc dampeners after 50/ 100 flights, and spindle sleeve , Aligns Factory pilots Colin,Jamie just to put there names out there fly harder then most do. (PM) Preventative maintenance is part of ownership of a heli just constantly fly and wait for something to brake or worse blow up just doesn't make sense flying heli with all this power.
Dino
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba
Dino Spadaccini is offline        Reply With Quote
Tags
800e, dfc, trekker
