Old 12-03-2012, 06:56 AM   #1
devilfish
Default t700 dfc to normal fbl head
I have a rex700e v2 with DFC head, and whant to convert to "normal" v2 fbl head.
What parts do I need?
Cheers
/// JR DSX9 2.4 \\\ /// TREX 450 SE v2 \\\ ///TREX 250 \\\
/// HYPERION 720i Net 3 \\\ /// PHOENIX Sim \\\
devilfish is offline        Reply With Quote
Old 12-03-2012, 10:30 AM   #2
treotraveler
Cheers
Longer stock main shaft, fbl head hub, fbl dampers, fbl grip arms and fbl 2.5mm links from swash to head grips should do it....
Trex 500esp fbl dfc 6s
Trex 600cf fbl 5 blade Hughs 530f TT 6s x2
Trex 600efl Pro fbl 12s Trex 700e v2 12s
Chaos 600e fbl 4 blade Blackhawk 12s Chaos 600e fbl Airwolf 12s BeastX DX8 DX18QQ TX
treotraveler is offline        Reply With Quote
Old 12-03-2012, 02:29 PM   #3
ualdrivr
While back I converted my FB Nitro to FBL with all the required parts from the 700E V2. Here is the thread:
http://helifreak.com/showthread.php?t=305486
I have all the parts listed there, some of them you'll need and some of them you already have.
Hope this helps.
At the precipice, we change!
Team GrandRC
ualdrivr is offline        Reply With Quote
Old 12-04-2012, 02:55 AM   #4
devilfish
Skickat från min LT18i via Tapatalk 2
Old 12-05-2012, 09:49 AM   #5
emilh
Could you please let us know if the longer main shaft (its lower part) fits the DFC frame? I think that this is the only problem that could happen with conversion to v2.
I list the parts needed in this thread:
http://helifreak.com/showthread.php?t=475648
Thanks,
Emil
emilh is offline        Reply With Quote
Old 12-22-2012, 12:05 AM   #6
Sladex
Is the DFC bad? I was thinking of doing the opposite of you, but now I'm re deciding my plan.
Trex 700E V2 - Canomod Phantom V2 Canopy, AR7200BX, CC BEC PRO
DX8!
Sladex is offline        Reply With Quote
