| Hurricane 425 Discussion and support of the Gaui Hurricane 425 |
Well, I have traded and deal my way to what I need to go FBL.
I have some Savox SC-0352 on the way to replace the old analog Futaba's on my cyclic. Traded some 450 servos for a FBL unit, it is a Turnigy V-Bar 600 (V3.0), which is a re-branded SJGD FS600 which I have done some looking into and seems to be a solid unit. I even got a stepdown on the way for my Futaba S9253 so it won't fry when I jump the BEC to 6V. All I need to do is convert the head to FBL. I am planning to take a spare FB cage part and cut them. Drill a hole at an angle into the blade grip and epoxy the FB cage part into the hole. This should give the proper distance for the link. ![]()
Gaui Hurricane 425 FBL with Robird G31 500 Class Rocks! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EFlight Blade 450 3D, Walkera Super CP Walkera Devo 10 w/ Deviation |
Don't sound to safe to me.why not get parts (G-204706) main grip lever assy & (G-204707)
upper swashplate lock assy.. ![]() |
#3 |
Agreed - all you need is the extended balls for the swash grip and a swash driver (Align or Gaui) total cost about $40, or if you are sticking with 425 blades you could even buy the Tarot 500 head for about $40
#4 | |
Drilling the grips is a bad plan.The extention balllink that screws directly on the grips is super cheap.
http://www.hobbyking.com/hobbyking/s...ss_Grips_.html Then you need a swash-follower that bolts to the mainshaft. Its around $15 from Gaui iirc. Read somewhere it is a good idea to run the metal washout guide assembly on the bottom of the main rotor yoke instead of the plastic one. not sure why thou. With all those mods your looking at ~$30/$35. A metal 500 size FBL head is even nicer if you stay with 435mm blades. (500mm+ wont fit in them) It gives a slightly larger disk (grips further apart) and looks really good on the Gaui. I got this one, but mine is un-branded http://www.ebay.com/itm/VWINRC-500-F...item27ccabf0cb Looks really good. fits perfectly. and flies really well. I could go absolutely berserk on pitch ranges. Arount +15/-15 collective and 16cyclic. I limited both at 12 degrees max. Just an estimated guess of what feels right. This one also looks nice to me, but i am not in need of another head at the moment. http://www.ebay.com/itm/Tarot-Flybar...item460a4fd38b
MSH Mini PROTOS <==> Clone 250/450 +night rig <==> GAUI Hurricane EP 425mm + 520mm Complete fleet equipped with Tarot ZYX Quote:
#5 |
You guys are right. Best do it right.
I like those extensions, I will see if I can get them. Otherwise I will get the Tarot 500 head.
#6 |
Something this big can hurt or kill someone so it's best to be careful and do it right without modifications.
Beating the air into submission... one Blade® at a time! Lynx Heli Innovations Team Pilot SilentDRC.net -The Order of Brushless Witnesses |
#7 |
OK, the extenders are ordered and someone is giving me the follower thingy. Things are coming together.
#8 |
I have asked around, someone local has a 500 size FBL head he is looking to sell, I may be able to do this high class.
#9 |
Make sure you take photos! Looking forward to seeing how you set this up.
#10 |
Here is a thread Vas did a while back with a very detailed explanation of converting to FBL using Gaui X4 and X5 head parts.
http://www.helifreak.com/showthread.php?t=289867
I don't need the latest and greatest. I just need more time to fly what I have. Helipro 450se, Gaui 200, Gaui 425 x 2, Gaui "HeadHunter 500, Gaui 550 |
#11 |
The extensions came in, they look good.
![]() The FB swash follower will work fine without the rest of the head if you can keep it from sliding down and falling off the two rods that keep it rotating with the head. I drilled two holes and put grub screws in them to keep it in place. ![]() Every thing is assembled, I just need to program and set stuff up. I hope to work on that this week.
Gaui Hurricane 425 FBL with Robird G31 500 Class Rocks! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EFlight Blade 450 3D, Walkera Super CP Walkera Devo 10 w/ Deviation Last edited by SQRT(-2); 12-17-2012 at 10:19 PM.. |
#12 | |
#13 | |
Hey, looks good!
Might do the same if i decide against the Flybar on my 520mm. Already have the controller and grips extensions at hand. If would be even nicer to push the mainshaft further in the hub fso it sits lower, but i see it wont leave any space for the swash follower.
#14 | |
![]() ![]() ![]() ![]() More info here http://www.helifreak.com/showthread.php?t=243114 |
#15 |
Looken nice, I may do that someday. First to get it to work.
#16 | |
omg Mike, that looks much better. now you really got me itching to convert it to FBL... Argh.
#17 |
Inspired by the last post in the above mentioned thread, I have modded the head a bit. I bought a threaded rod and cut to length. I covered the middle with some heat shrink to dress it up a bit.
![]() The FBL unit I traded for is beginning to behave oddly, If I can't figure it out I may just go with a Robird unit. It looks like a decent setup, I have heard it compared to a BeastX. At half the price I am considering it.
Gaui Hurricane 425 FBL with Robird G31 500 Class Rocks! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. EFlight Blade 450 3D, Walkera Super CP Walkera Devo 10 w/ Deviation Last edited by SQRT(-2); 12-22-2012 at 10:44 AM.. |
#18 |
Aspiring FBL converts might find this manual useful.
http://www.gaui.com.tw/html/program/...oad.asp?sn=564 If you don't mind the plastic main blade grips, it is just a 30$ head upgrade. (204707 + 204706) I know gaui keep changing their file links, so i've attached it just in case.
-roger Compass Atom 500 FBL, GAUI hurricane 425EP |
#19 |
Hey SQRT, are you still flying this head setup, .ie. what looks like the stock plastic grips with the Gaui fbl extensions screwed into the grips? Are there any issues with this that you have had?
I'm pondering transitioning my 550 to mid-boom and getting another G31 for the Gaui given how great my 450 is flying with that electronic marvel. |
#20 |
Yes, and another guy at my field has been doing it for a while too. No problems. Now I suspect breaking the blade grips in a crash may be more likely, but they are cheep.
