| Realtime Video and FPV Discussions of receiving video in realtime from the aircraft |
Hello.
I have a wonderful amount of fun flying indoor fpv with my qr ladybird in the sports hall where my club is at. Actually i fly my ladybird more around the cafetaria instead of in the hall itself ![]() I do have trouble with interference. My fpv-system is 5.8 ghz and most halls i fly in are steel constructions. I end up with lots of flicker, sudden black-white image, sometimes colors which i cannot identify.. multipath. I hoped to solve this problem by replacing my stock rubberduck antenna on my receiver with a circular polarized one. It helps a little, but it is still not ok to me. So theres no other solution left but to install a circular polarized antenna on my vtx aswell, which will add even more weight to the little thing, and on the frame, theres alllready so little space. I also use pretty heavy 550 mah flight batteries, because i seem to get the longest flight time with them. (5 minutes) So.. i decided to try something radical. I dismanteled the ladybird and made a new frame which is 2.5 grams lighter then the stock one (5 gram) while the center point is significantly bigger to get me more space to install my fpv-electronics. The material that i used for this building project is not very common in our hobby, but it sure does what it needs to do picture time => ![]() ![]() Indeed, the same stuff you find in packages of computer parts/tablets... ![]() 4 little pieces of balsa ![]() basic frame is ready... ![]() Now to fix the motors. Used strong glue to attach it to the frame and the end point of each piece of balsa ![]() 4 extra pieces of whateveritscalled to give a bit of support to the pieces of balsa. ![]() I forgot to take more pictures, so all i can give now are pictures of the end result ![]() ![]() ![]() First flight tests were positive. Next step is adding a circular antenna to the vtx This is my very first building project and i am pretty proud of it ^^ greetings Robby |
Pretty sweet man! Way to think outside the box...
No I didn't misspell Daneger, my name is Dane..get it? To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. "Flyin' high again..." -Ozzy Osbourne |
#3 |
So if you ship it, what would you use for packing material?
Custom quad copter, Cobra C-3525/18 motors and ESCs; APC 15x4 thin electric props. OpenPilot ControlCopter board. Futaba 8FG Super 2.4 gHz FAAST system. |
#4 |
#5 |
Hello.
following is the result of my nano fpv project (2.0) I made a brand new frame since my previous one in this very same topic is not really solid and pretty messy. I got the idea for my 2.0 nano quad from this => ![]() a 3d-puzzle! Further explanation is not truly needed when watching the pictures below ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() material: balsa and foamplate with about the same characteristics as depron. sweet detail: not A SINGLE DROP of glue has been used to keep this frame together. only for attaching the motors and elektronics i used elapor ca glue and regular ca glue for the motors. Because of this, every little piece can be replaced without much hassle greetings Robby |
