Old 01-05-2013, 01:24 AM   #1
thefrog
Default How does the cyclic ring option work?
Guys I have the cyclic ring option checked on my units but I've never bothered to check if/how it works. In setup mode on both my helis I get binding at extreme throws (places you should technically never that the sticks) but have no idea if the throws will be limited in flight and how I can check this.
Anyone got some experience? Should I just power up in normal mode and try max throws?
thefrog is online now        Reply With Quote
Old 01-05-2013, 12:49 PM   #2
georgi UK
=] Froggy, I never like to know my servo's can bind at extremes even when I don't use those movements, the SK ring is usually pretty good on mine, what you get in setup mode is actual for flight mode, swash balls correct?
georgi UK
georgi UK is offline        Reply With Quote
Old 01-05-2013, 01:01 PM   #3
thefrog
I'm also not happy about it Georgi, but if I want to run the throws then this is the problem I have. I'm also not doing anything serious - +12.5/-12.5 and 9 on cyclic.
Pity there is no way to adjust it.
Old 01-05-2013, 01:11 PM   #4
georgi UK
=] where are you getting it binding, heli type?
georgi UK
Old 01-06-2013, 12:45 AM   #5
johnahamelv
My guess is the T-Rex 600Pro using the INNER cyclic servo horn holes. Left and right cyclic servo links binding against servo cases when on low collective stick and extreme upper corners of cyclic stick.
Whiplash E--ICE2HV160/KDE-495/MKS HV's, Synergy E5/S--ICE2HV120/KDE-530/Futaba HV's
T-Rex 600Pro XT--ICE2HV120/KDE-530, T-Rex 550--ICE100/KDE-1175, B130X, mCPx
VBar Silverline x4, Lots of KDE, DX8, Sims: Aerofly5.7 /RF6.5/Phoenix 4
johnahamelv is offline        Reply With Quote
Old 01-06-2013, 12:59 AM   #6
thefrog
I'm getting elevator arm touching the frame on both my Srimoks - N and E. They have different frame and servo layouts but the same issue at extreme throws. With VBar I think you can set the % of cyclic ring so this won't happen.
The throws where this will happen is full positive collective plus full back elevator. Not something I ever expect to do. Been living with it but was wondering how to work around it.
Old 01-07-2013, 06:26 AM   #7
RiazP
Dude, i tried to move the swash up, fiddled with the links and the only way i got it to stop was to either limit collective pitch or to cut the frame, found that 11.6 was the most i could get if i adjusted the center servo driver to sit above horizontal, while also making the swash links a little longer.
Even with my very conservative flying style i didt like the feel on the nitro, so i trimmed the frame and reset all the links to standard and can now get 12.7 at a stretch with no binding on the frame or from the swash on the t piece at full positive and full right cyclic
250 DFC|450 Sp,SK720,TT,KDE,NUE1107h/2y,cc50,4s|450 PRO DFC,SK720,KDE,Scorp 2221-8,cc50,4s|KSM Srimok 90n LRH,SK720,OS Speed 3D,Hatori#968,ds8917HV, BL9180, BL9188,gvr7020,MGovPro
RiazP is online now        Reply With Quote
Old 01-10-2013, 12:45 AM   #8
rallyant
I have always wanted to know this too.
What exactly does the swash ring check box do?
___________________________
Sent via Android, Tapatalk. 7HV, Atom, Warp,
rallyant is online now        Reply With Quote
Old 01-10-2013, 02:10 AM   #9
thefrog
The way I understand it its supposed to limit the total travel for collective and cyclic input within a 'ring' - e.g. limit total output to, say, 20*.
Old 01-10-2013, 02:20 AM   #10
rallyant
What sets the ring limits?
With vbar you set the limit . But with skookum there is no extra setting.
Old 01-10-2013, 03:15 AM   #11
thefrog
It would be great to have a measure of control over the ring value.
