600 PRO Class Electric Helicopters 600 PRO Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
09-19-2013, 10:36 AM | #1 (permalink) |
Align 600 DFC Pro - Pinion for 2300-2400 RPM's?
I had a few issues on my 600 DFC (stock 510kv motor, ICE2 HV80 ESC) and decided to go through my ESC settings. Originally, I was running governor high and realized the 2200rpm's that I had wanted for IU2 was in fact much higher (around 2400-2500). I changed to SET RPM and now my headspeed is down to 2200 rpm which is too slow for me now. This is currently running 12s.
What pinions are you guys running for 2300-2400rpms's? Are you experiencing any problems with these head speeds? The problem with the current 13T (stock gearing, 8.615 gear ratio) that I am running is that it limits me to 2230 for a motor efficiency of 95% and Castle has advised me against going with anything higher with the current gearing with SET RPM.
Goblin 770 Competition - Goblin Black Thunder 700 Stretch - Goblin 570 - Vortex 250 PRO Last edited by AnthonyV; 09-19-2013 at 11:39 AM.. |
09-19-2013, 08:20 PM | #2 (permalink) |
You can get the newly released upgrade allowing you to run the 700mx motor or run it ungoverned 95 flat or even 100 flat I HATE GOVERNOR run it wide open! You should hit around 2500 beginning of pack if jot more
Team Grandrc.com Team Novarossi Motors U.S.A PlanetHobby.com "PushGlo" "SwitchGlo" Byron Fuels 2018 |
09-20-2013, 10:42 AM | #3 (permalink) | |
09-23-2013, 01:12 PM | #4 (permalink) |
Mike A - You are correct.
I met with Clint from Castle Creations over the weekend and he explained everything in great detail to me. Basically, you could technically set the headspeed as high as you want but the motor power will never exceed 100%. So if you set it at 3000rpm head speed, the highest you'll get is 100% of the motor which would probably be around 2450-2550 depending on the KV of your motor, torque values, etc. Also, the deal about having it at or below 95% does not matter because again the motor will not exceed 100%. As you said, they calculate this at 3.7v and always allow a decent amount of headroom (5-10%) for their calculations. I'm back at 2400 rpm at set RPM and it's running great
Goblin 770 Competition - Goblin Black Thunder 700 Stretch - Goblin 570 - Vortex 250 PRO |
10-02-2013, 09:29 PM | #5 (permalink) |
I have mine gov'ed to 2350 using stock gears and pinion
I do have a KDE xf-530 motor in it and my gov is setup at 94.5% at 2350 I believe it worked out very well
4 x Rush 750/stretched V-bar KDE 700XF-495 HV servos Greys reactor CC 160-HV Trex 600EFL V2 V-Bar ds610 ds650 CC bec/pro Scorpion 130a HV KDE 600XF-530 450L KDE 1750 cc50 4xDS215MG k-bar X-8 FPV Wing, TBS Discovery FPV, TBS Caipirinha FPV |
08-30-2016, 06:18 AM | #6 (permalink) |
For those of you running 2300 to 2400 can you let me know what blades you are using? Been running align 600 blades that came with 600l dominator at 2450. Just noti ed after about 200 flights or so that my blade holes are starting to elongate
Goblin 380 KSE - MSH Brain2 / HW60A V4 Trex 500l Dominator- MSH Brain / HW100A Pro V3 Trex 600l dominator- MSH Brain / CC Edge 80HV Synergy E7se - MSH Brain / CC Edge 120HV |
08-30-2016, 06:41 AM | #7 (permalink) | |
I run my 600 at 2450 using Align 600 3G Carbon Fiber Blades (AGNHD600E) and Align 600 95mm Carbon Fiber Tail Blade (AGNHQ0950B) for the past three years and I haven't noticed any issues like you described, yet! Carlos |
08-30-2016, 07:46 AM | #8 (permalink) |
Running 2200 and occasionally up to 2350 and Align 600mm new edition blades, I have never had an issue with bolt hole elongating even after 300 flights on a set. Maybe your blade bolts are not in a good shape and are eating up the blade hole. Also ensure that you run your blades tight (I run mine very tight). And lastly, if the blade inserts are worn down but the actual CF around the holes is fine, then you may be able to swap the inserts out for new ones from another blade. After all, these inserts are removable.
Stock pinion with 600mx and Castle held great at 2350 and only time I felt the governor maxing out was when running a tired set of batteries.
Andreas M. Compass 7HVU Logo 600SX V2 Blade 450X |
08-30-2016, 05:01 PM | #9 (permalink) | |
Agree if pwm and timing are setup right governer works well at 2300 2400 but i found sweet spot at around 2450. Might just get another set of aligns as they fly good enough for me. Sent from my SM-G928I using Tapatalk
