Go Back   HeliFreak > R/C Helicopter Support > KDS Helicopters General Discussion
KDS Helicopters General Discussion KDS Helicopters General Discussion
Old 01-20-2012, 06:21 PM   #1 (permalink)
Default KDS Li-po Battery Problem and Questions
Thanks in advance to all who may elect to help here, it is greatly appreciated.
This is a new KDS 450 SV (no FS yet) and I'm new as hell to electrics and heli. I'm doing the learning curve and made it to the point that the setup needed to be checked. So to crank up the servos I used the provided (in the kit) KDS charger and after several hours of blinking green, I removed the battery noticing the steady green was not there and wondered if the batt charged. 1st mistake was not checking the voltage before and after this 1st charge.
I used the battery about a dozen times for just a few minutes each testing and such and the reciever began to flash instead of the steady red that I was accustomed to seeing, then the servos went dead. OK batt needs charging I thought, so I plugged it back up and the charger's red and green lights are both flashing. HMMMMMMM!... Votages were measured and I got 8.6V from the discharge leads, 8.6V from cell 1, 5.8V from cell 2, 2V from cell 3. Reading from outside lead towards the common lead. After researching this some I see that I stayed inside the 80% 8.8V rules by .2V.? Anyways, is this a bad battery from the box? Did I screw it up by running it too low? Can this be fixed or is it ruined? And of coarse, do I need to get a different (better) charger?
Rubberhead's head hurts!!
Rubberhead is offline        Reply With Quote Quick reply to this message
Old 01-20-2012, 11:58 PM   #2 (permalink)
I'd say you should use a better charger. Even just charge it on someone else's and see what condition there's says the battery is in?
Can't comment on the rest because I'm not familiar with the heli but when I stop trusting something as important as a battery I know what I'd do!
rebeltrousers is offline        Reply With Quote Quick reply to this message
Old 01-22-2012, 06:41 AM   #3 (permalink)
Default Follow up
While exploring all of this situation, I plugged in the battery again and made sure the power and charger were all settled in and then plugged the battery in just in case I did something different 1st go around. The charger green light began flashing and continued for another 3 hours or so, it never went to solid green. The discharge leads tested about 12.2V or so so I am continuing to use it for pre-flight setup tests and etc. but I will definitely get a good charger for anylsis before I fly it, spare batteries or on the way too.
