Belt CP E-Sky Belt CP
Old 04-27-2008, 04:17 AM   #41 (permalink)
Don, welcome to THE Belt CP forum.
There are many things you can do to the belt - as the threads here show. Of particular note is the "Compatible Trex parts" thread, which gives you an idea of what we can upgrade. As regards servos, most opt for the TowerPro sg90, a straight fit, and easy upgrade.
We aim to help here, so leave no query un asked!!!!!!!!!
Mike
Happy Heli-days !!!!!!!! Skip
T-Rex 450Sport, T-Rex 500ESP,
T-Rex 600NSP FBL, OS55, MicroBeastX Plus,
Futaba 14SG,
helihathnofury is offline        Reply With Quote Quick reply to this message
Old 05-04-2008, 07:41 AM   #42 (permalink)
Hi
Just realised I hadn't posted any details of my DTS mod on this site.
I used a slightly different approach from the other mods on this thread. I only did the back two servo's because on mine the front link is smooth and slop free so I didn't reall see the point. Instead of using stock brackets I fabricated my own from a plastic condenser cover
from a car radiator but any suitable plastic or ally angle section would do as well.
The plastic is Just over 2mm thick and is very strong, it feels like the same stuff the frame is made of which seems to be standing up to my beginners knocks really well.
I feel the overall appearance is better than the off the shelf brackets as the 90 degree
angle looks part of the heli and not like an obvious add on.
I may make another pair with slightly different dimensions, if you notice the servo's are set a little wide in the mounts on these.
Also the UGT 05 swash plate I used is very wide and throws the links out of line slightly.
It's not enough to adversly affect its function but If I can find a smaller one with the AR pin on the right side I will be able to reduce the servo throws accordingly and that will reduce any differential induced negative expo caused by the servo arc..
Still I am pleased with it for a first attempt and it only took a few hours to do.
The heli definately flies much better with the mod
All the best Ian
Trex 500 ESP
Phoenix Flasher 450
Frankenbelt
Ian 777 is offline        Reply With Quote Quick reply to this message
Old 05-04-2008, 08:26 AM   #43 (permalink)
Very good job Ian...... your copter looks the biz, and that metallic blue head is much more in keeping than my pinkt pEsky CNC stuff.
Futaba 14SG,
Old 05-04-2008, 08:32 AM   #44 (permalink)
It's great quality stuff for the price Mike though could do with finding a more appropriate swash, May get the pesky one and re anodise it.
I know I keep on about this Copter X head but it's such a bargin and I'm sure my heli flies as well as most Trex 450's
Trex 500 ESP
Phoenix Flasher 450
Frankenbelt
Old 05-04-2008, 09:51 AM   #45 (permalink)
For some reason, I seem to be have poor pitch control. Roll is fine, as is collective, but the pitch is really much less responsive. All the servos are ok, swash is nice..mmmmmmm??????????
Futaba 14SG,
Old 05-04-2008, 08:22 PM   #46 (permalink)
Pitch = Collective..
you mean you have poor elevator control.. Thats becuase of the play in those links you never did the front servo.
DierWolf is offline        Reply With Quote Quick reply to this message
Old 05-05-2008, 12:45 AM   #47 (permalink)
Hello Ian
Nice mod and very good pics. I like it ,its much easier to change a servo if bad things happen to it
Anything that flies
Ber60 is offline        Reply With Quote Quick reply to this message
Old 05-05-2008, 02:26 AM   #48 (permalink)
Mike did do his front servo Its me that didn't my elevator control is really good
Trex 500 ESP
Phoenix Flasher 450
Frankenbelt
Old 05-05-2008, 03:02 AM   #49 (permalink)
[quote=DierWolf;661124]Pitch = Collective..
Sorry Wolfie, "returning back to type", as we say. Collective pitch was fine, it was elevator pitch which was reduced. All fine now after a bit of silicone oil lube and relaxing a couple of nuts, if you pardon the expression!!!!!!!!!!
Mike
Futaba 14SG,
Old 05-08-2008, 11:40 PM   #50 (permalink)
Mike
I have been lurking on other forums and the SG90s have been coming up as a replacement for the ESkys 0500. Another suggestion has been DY (Dong Yang) 9gm units even cheaper than the SG90s. Anyone had any experience with the DY units?
Don MacLachlan is offline        Reply With Quote Quick reply to this message
Old 05-09-2008, 07:26 AM   #51 (permalink)
The dong Yang servo's i believe are those servos with the red or blue bottom section, i have seen a couple people have them on their heli on other forums and really they didnt say anything bad about them.
They are digital servo's which might become a problem power wise when using 4 or even 3 of them with the Esky Belt CP ESC.. so i would not recommend them if your sticking to the esky ESC.
For everyones reference this is their site. http://www.dys.hk/
This is the ones i want the review on, its new for 2008, looks just like the SG90 but has all metal gears.
http://www.dys.hk/ProductShow.asp?ID=374
Pic.
Specs:
Item No.YS0219
*Weight:15g
*Size: 23.0*12.5*30.0mm
*Speed : 0.10sec/60o
*Stall Torque: 1.7 kg/cm
*Operating Voltage:4.8-6Volts
Old 05-12-2008, 02:30 PM   #52 (permalink)
Default carbon upgrade
Can this mod to the direct to swashplate be done to a carbon frame upgrade with the Servo Tray Mini Titan E325???
ianc is offline        Reply With Quote Quick reply to this message
Old 05-12-2008, 02:36 PM   #53 (permalink)
Yes..
Look thru the thread, someone posted their Carbon Fiber Frame version of the mod.
Old 05-12-2008, 02:41 PM   #54 (permalink)
Thanks Dierwolf I missed that Thread, I'll be getting to work on it when I get my servo trays
Old 05-12-2008, 02:42 PM   #55 (permalink)
Its post number 27 in this thread...
Old 05-23-2008, 12:59 PM   #56 (permalink)
Been looking at your mod for the DTS again, Ian. Having buggered ny frame, I might do a similar bracket idea, as this will add to the frame strength, not take some away. So now I am on the hunt for some plastic with a 90 angle to have a go when my new frame comes!!!!!!!!!!
Mike
Futaba 14SG,
Old 05-23-2008, 01:23 PM   #57 (permalink)
I am considering a new alu frame, I have ordered the the plastic upgrade set and will investigate if a alu frame can be made easely
Anything that flies
Old 05-23-2008, 02:53 PM   #58 (permalink)
My buddy at the shop is getting a new cnc machine, i may start making my own frames soon as well....
Figure out i just ship them all up to the EX in Miami as bulk and she can ship them cheaper for me from there.
Old 05-31-2008, 04:22 PM   #59 (permalink)
I think i am going to do this when i get my scratch built g-10 frame built and i get a programmable radio.
onehot69stepside is offline        Reply With Quote Quick reply to this message
Old 05-31-2008, 04:27 PM   #60 (permalink)
Any chance of pics of the frame
Anything that flies
